Head gasket failure/replacement - Dodge SRT Forum
post #1 of 29 (permalink) Old 07-12-2011, 05:52 PM Thread Starter
New Member
Quoted: 0 Post(s)
So I suspected a head gasket leak, short drive and pulling the plugs show coolant in every cylinder. Engine has 1640 miles on it, with the first 1300 being on 8psi and the rest at 15psi. Block was said to be straight by the machine shop and the head I didn't check since it was brand new from DCR. I used a stock replacement felpro MLS head gasket dry without any of those copper sprays. The only explanation I have for this is that the head studs came loose, which would explain the coolant in every cylinder.
I know there are plently of people running 400+ on the stock head gasket. So what is the standard for head gasket replacement for someone looking to make 500+? Should I go with the same gasket and one of those sprays or something different? The only other gasket I know of is DCR's 5 layer and cometic's MLS.
Looking for reccomendations to keep this from happening again.
Thanks
Mod List: Built 2.4 with DCR Pro-Mod and a BW/AGP S-360RS along with every supporting mod. Currently 8psi a need bigger wheels/tires.
boostalot717 is offline
post #2 of 29 (permalink) Old 07-12-2011, 05:55 PM
Spoolbus's Avatar
Quoted: 0 Post(s)
APR head studs, realtune 5 layer HG, spray the copper on both sides and have the head checked even if it's from DCR you never know.
Contact Turbo666 for all DSP/SCT tunes
Spoolbus is offline
post #3 of 29 (permalink) Old 07-12-2011, 06:22 PM
New Member
Turbolag87's Avatar
Quoted: 9 Post(s)
I run stock with studs
Autoguide
AGP Twinscroll s256
+1 Race head, Race ported IM
BC 2 cams
Built Motor
Meth Injection
11.4@125mph (old times,S3, stock head and cams) 26psi)
Turbolag87 is offline
post #4 of 29 (permalink) Old 07-12-2011, 06:25 PM
Spoolbus's Avatar
Quoted: 0 Post(s)
^^^ stock studs are fine, I went 11.03 @ 129mph with them making 407whp and 447wtq on Nigels dyno, completly stock longblock & realtune BW stage 3. But once you remove them like the OP has, I wouldn't recomend re-using them.
Spoolbus is offline
post #5 of 29 (permalink) Old 07-12-2011, 08:17 PM Thread Starter
New Member
Quoted: 0 Post(s)
cool so i should have been good. Maybe I didn't give it enough time before upping the boost. My butt dyno guess is that is was around 350-400 at 15psi, maybe to much.
Whats the difference between realtunes and dcr's headgasket? Just curious.
post #6 of 29 (permalink) Old 07-12-2011, 09:17 PM
Spoolbus's Avatar
Quoted: 0 Post(s)
About $50 difference:
Realtune: 03-05 Dodge Neon SRT-4
DCR: Darrell Cox Racing - 5-Layer Head Gasket (Powered by CubeCart)
Spoolbus is offline
post #7 of 29 (permalink) Old 07-12-2011, 09:31 PM Thread Starter
New Member
Quoted: 0 Post(s)
LOL ok sounds good. I thought maybe there was a material difference or something.
post #8 of 29 (permalink) Old 07-12-2011, 09:35 PM
Spoolbus's Avatar
Quoted: 0 Post(s)
Nope just 2 stock gasket minus one layer riveted together
Spoolbus is offline
post #9 of 29 (permalink) Old 07-12-2011, 10:37 PM
New Member
Quoted: 1 Post(s)
i reused my stock ones 3 times and went 10.9/128 then put on a bigger turbo but never got to the track
arp studs and stock gasket will do fine
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
^^Stock Turbo no n2o
"RIP" 3147 10.93@128.58 25psi 7.099/103.54
11.05 pump gas
dansrt4 is offline
post #10 of 29 (permalink) Old 07-13-2011, 07:40 AM Thread Starter
New Member
Quoted: 0 Post(s)
going to get ahold of them and see if they can get it here by the weekend, if not just going to get a stocker and spray it with that copper stuff. The other question I had was I went with ARP's torque specs for their stud kit. Is that what everyone else is doing or going a little higher? Also not sure if my stud kit has the bigger washers that I have heard about, anyone know the size difference between the two?
post #11 of 29 (permalink) Old 07-13-2011, 09:13 AM
SRTotM Moderator
Bad98rt's Avatar
Quoted: 1 Post(s)
i tq'd mine to 92ft/lbs and never had a issue.....and i sprayed both sides of the HG with copper spray.... and also the washer issue was chamged many years ago... if you still have the boc call arp and see if they can run the lot number to see when it was manufactured
Huge thanks to Chris, Bill, And Bob @MAPerformane for 95% of all my parts
Huge Thanks to Kevin Warren For.. Many many things
MAP EF4 stock block, stock head
452whp on EMS at 26 psi
100&92 octane mix
Fully built long block and big numbers coming!
Bad98rt is offline
post #12 of 29 (permalink) Old 07-13-2011, 10:06 AM
Mopar McNeer's Avatar
Quoted: 1 Post(s)
What copper spray are people using?
Do you spray the entire head gasket with it or just certain areas?
AGP 50 Trim .82 A/R, Turbo666 DSP Tuned, Fully Built JP Pistons/BC Rods, DW 750 Injectors, Ported Intake w/ LFS 60mm, AGP Big FMIC, Crane #14 Cams & Cam Gears, Ravenworks CNC Ported w/ Indy Values, ED 3" Exhaust w/ Ported Exhaust Housing/Manifold, Walbro 255 & AGP Returnline w/ Bottleneck fix & Fuel Pump Rewire, HKS SSQV, Tial 38mm WG, ACT 6 Puck, Pwerks Billet Input Shaft.
Click to See my SRT
Click to see my old Avenger- RIP
Mopar McNeer is offline
post #13 of 29 (permalink) Old 07-13-2011, 01:23 PM Thread Starter
New Member
Quoted: 0 Post(s)
You torqued yours to 92 and left it there or did you do the extra half turn also that it reccomends?
The copper spray I used on other cars was available at the local parts store in a aresol can. Spray the whole gasket, both sides.
post #14 of 29 (permalink) Old 07-14-2011, 10:52 AM
SRTotM Moderator
Bad98rt's Avatar
Quoted: 1 Post(s)
i tq'd it 30,60 92 then the 1/4 turn with a real ratchet......
100&92 octane mix
Bad98rt is offline
post #15 of 29 (permalink) Old 07-14-2011, 12:00 PM
New Member
jwcardy's Avatar
Quoted: 0 Post(s)
there are many factors that can cause a head gasket to fail...is the tuning spot on?
04 srt4 with pte5862
04 built/boosted 35r s2k
jwcardy is offline
User Tag List
Linear Mode Linear Mode
