Old 05-04-2008, 03:57 PM   #1 (permalink)
Member Number: 22854
Trader Rating: (12)
Default Got a problem and I'm confused
I recently replaced the head on my car and everything is back together as it should be. The car is timed correctly but it won't start. When I turn the key it grumbles like its trying to turn on but is choking. However if I pull out the #1 sparkplug it fires right up. little history, the car sat for about a year before I replaced the head. Is there something that I'm missing here?
POWER: 3" cai, Cold side pipe, 60 mm tb w/spacer, W/I, 3" full catless turboback, 255 fp, s1 inj, profec ebs, NGK AFX
SUSPENSION: trac bars, torsion bars, sways, strut bars, 17x7 rims, 225 tires
WAITING FOR MY LAZY ASS: 60-1 turbo, AGP log style, 38 mm w/g, recirculated 3" o2 housing, PTP FTM, race head.
Soon, very soon...
Speicker is offline   Reply With Quote
Old 05-05-2008, 08:43 AM   #2 (permalink)
SRTforums Veteran²
onthedwnlow's Avatar
Member Number: 27125
Trader Rating: (46)
did you install aftermarket cams?......are you sure the cam magnet was installed properly?
sorry guys but the car is for sale....all out first gen is in the works
onthedwnlow is offline   Reply With Quote
Old 05-05-2008, 06:53 PM   #3 (permalink)
GreaseMonkey69's Avatar
Member Number: 43017
Trader Rating: (18)
ok so it wont start period until you pull out the #1 spark plug? well i would double check timing make sure the cams and crank are at tdc. the crank can be tdc but the cams could be off. if that would be the case the car would run funny and idle very hard. check the #4 spark plug too since they are on the same stroke. the car can run on 1 good cylinder on the same stroke but sound like shit. i would take the valve cover off and inspect to make sure the cams on #1 are tdc. making sure the crank is at tdc as well. if they are aftermarket cams make sure the cam magnet is placed at the 4'o clock and 5'o clock position. check your coil and spark plug wires as well. are you pulling any engine codes?
SRT-4 is built in the US with 84% US content.
A New 06-07 Mustang is built in the US with 64% US content and does not legally qualify to use the term "Made in the USA". How's that for an import? Stock turbo/ 3'cai, 3"O2 housing, 3"DP, AGP WGA, mild port head w/3angle valve job w/crane springs retainers,2.0 cams w/fidanza gears, ED hard pipes, hks bov, ported 55mm tb. thats just the begining
GreaseMonkey69 is offline   Reply With Quote
Old 05-05-2008, 06:56 PM   #4 (permalink)
quickshift's Avatar
Member Number: 55168
Trader Rating: (29)
sounds like the timing is off....myne sounded that way when my timing was off......
BEST ET: 12.68@110 stg 0, stock turbo, stock intercooler, pump gas, & no meth
MODS ADDED SINCE THIS RUN: AGP BB .50T with all supporting mods
quickshift is offline   Reply With Quote
Page generated in 0.13387 seconds with 11 queries
