Old 04-18-2008, 12:40 AM   #16 (permalink)
Member Number: 32196
Quote: Originally Posted by taco View Post
They are generally slow to respond because it's an outside person who deals with customer service.
I'm about as direct as it gets without actually speaking to the owners. I'm at the shop almost everyday. I take orders for them and I take care of customers when I can
I had their motor mount kit no problems.
I was looking @ their tb it's 70mm my question is can the stock im be ported to 70mm to match the tb? Why don't they offer a ported 70mm im to go with the tb can you ask them thank you.
Sean
A853 Crew (ONLY UNO)
Starting all over from stock
Mods Now04 Silver Wilwood slotted BBK slotted,slotted Rear,Windage tray+crank scraper,Dcr power shift2 clutch,Bwoody Motor mounts+trany,Stock air box mod+K&N drop in,F&F Ported ex.Manifold,3" o2 housing,My catch can+check valve,Safc Neo,Agp waste gate + ptp spring,Agp uhp,lower
^ Coming Maxed Stocker WORLD RECORD 08
Racerxvsspeedracer is offline   Reply With Quote
Old 04-18-2008, 01:17 AM   #17 (permalink)
Member Number: 58932
Sean
sean, to my understanding, the intake mani can be max ported to 69mm before the walls are too thin and concave..
mine is ported to 69mm
i run the boomba w/ the stock (2.5in.) pipe adapter.
if i could do it over again, i would. this TB is the shit.
Old 04-18-2008, 01:35 AM   #18 (permalink)
So with it ported to 69mm it's still safe (safe meaning not going to break still strong as stock was) And who did your port work thank you Mike.
Sean
Old 04-18-2008, 01:39 AM   #19 (permalink)
Sean
yea. from what i know, if you go any bigger, you have the potential for the throat to break and wear thin.
reed ported my intake. he took a shitload of material out and went pretty far deep into it. it had no lip after it was done.
its running on stock size cold pipe, but i want to put the 70mm TB piece (there is a 55mm adapter for the stock size pipes) along w/ a 3" coldside to match it so it gets used to its full potential.
def. worth the money. the response was crazy as shit going from my ported stocker to the 70.
and no problem.
Old 04-27-2008, 07:55 AM   #20 (permalink)
SRToc Member
MikeD's Avatar
Member Number: 2830
Trader Rating: (60)
Not only had they better be hawt looking, but yes, need to be highest quality. For that kinda coin you can get some UR gears
|DCR Pistons| |DCR Rods| |OE crank| |DCR bearings| |DasMotorsports head| |Crower springs| |Crane 16 cams| | UR Cam gears | |AGP turbo manifold/Psi-Fi turbo| |Psi-Fi intercooler| |JMB CAI| |JMB ported intake manifold| |LFS 60mm TB| |NX wet kit, etc., etc.|
Should be 13's, for sure
Yours for the right price! (Cheaper then you think!)
MikeD is offline   Reply With Quote
Old 05-01-2008, 08:46 AM   #21 (permalink)
Member Number: 28737
Trader Rating: (66)
Sorry for disappearing for a while. I should be seeing the gears this week or early next as long as things stay on schedule.
As for the throttle body/Intake manifold question...Boomba used to do somehing with the manifolds but from what I know it was too much of a pain for them to get it into the machines and setup. I think I can still get it done but I'd have to check. And like it was stated, the intake manifold has no lip at al if you port it out match the throttle body. It's nice for the airflow
taco is offline   Reply With Quote
Old 05-04-2008, 11:51 AM   #22 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (15)
I've always wanted to try Boomba parts but have always been turned off by other peoples' claims that they never respond to support or tech problems. Their parts look amazing, though.
Powered by Turbonetics, South Bend Clutch, Wiseco, Crower, PTP, Realtune, Pwerks, SCT, DSS, AGP, HKS and some 93 octane!
Old 05-09-2008, 11:46 PM   #23 (permalink)
dawm's Avatar
Member Number: 2695
Trader Rating: (31)
if they make them flat like the AEMs but with less openings, they wouldnt crack/fail like the fidanza's. the reason the fidanza's fail is due to the machining they do which leaves a sharp edge/corner which is where they all crack at.
2002 MTX 4DR SOHC 2.0L R/T ~ Going back to stock
AFX FSTB, PWerks RSTB, Tokico HP, Eibach ProKit, Prothane RACE inserts, FF Longtube v2, 2.5" Dynomax, MP STS, Boogers, SRT-4 Seats
1998 MTX 2DR DOHC 2.4L TURBO R/T ~ Motor almost finally assembled
http://www.neontuners.com http://www.detroitneonowners.org
dawm is offline   Reply With Quote
Old 05-14-2008, 10:52 AM   #24 (permalink)
Technical Tuning & EFI/EMS Electronics moderator
sour kraut's Avatar
Member Number: 19796
Pics needed.
sour kraut is offline   Reply With Quote
Old 05-14-2008, 06:58 PM   #25 (permalink)
Trader Rating: (66)
I have 2 sets done right now. Working on getting a dozen done before the weekend. If I had my camera I'd put pictures up but I don't sadly
Old 05-14-2008, 07:42 PM   #26 (permalink)
Member Number: 18856
for 350 i better be getting my moneys worth you can find fidanzas for $170 online for our cars.
not a thing just another slow ass neon
joe smalls is offline   Reply With Quote
Old 05-15-2008, 06:31 AM   #27 (permalink)
Trader Rating: (66)
Nobody is saying you can't buy Fidanza gears
Here is a quick picture
Old 05-16-2008, 11:54 AM   #28 (permalink)
Member Number: 64119
5-bolt... FAIL
might as well as get fidanzas w/ upgraded bolts.
what a shame
Santiago. is offline   Reply With Quote
Old 05-16-2008, 12:40 PM   #29 (permalink)
moparmansrt4's Avatar
Member Number: 50684
I thought you were going to talk them into rocking the 3-bolt like the AEM's.
Quote: Originally Posted by rollwitstyle View Post
the srt is the worst car to buy it sucks so much balls and tastes like doo doo. buy the t/a they are the fastest cars ever and they taste like steak....... by the way pm me atleast a week in advance if you plan to visit ny
http://www.srtforums.com/forums/f106...ml#post5894846
moparmansrt4 is offline   Reply With Quote
Old 05-16-2008, 01:05 PM   #30 (permalink)
tamadx's Avatar
Member Number: 26290
Trader Rating: (18)
will having 5 bolts really cause a problem?
S2, WGA, SST V2, Return Line, CAI, Turboback, BFMIC, 55mm TB, DTEC, Wideband, W/I, Scan Gauge, Ported Stuff
tamadx is offline   Reply With Quote
Page generated in 0.28452 seconds with 11 queries
Search Engine Optimization by
