engine tick and odd cam grooves - Dodge SRT Forum
post #1 of 31 (permalink) Old 10-02-2012, 10:38 PM Thread Starter
mayhem's Avatar
Quoted: 0 Post(s)
so i have a ticking noise coming from cylinder 4. i have pulled the spark plug boot while it was ticking and the tick went away, so tells me its cylinder 4. i have done the cam cap fix on all of the caps. the tick starts about 2000rpms to 4000rpms or unless i hit boost then it goes away. last time we took the valve cover off we found odd wear marks on the cam lope by cylinder 4.
i feel like the next move is to buy lash adjusters.
thanks guys any ideas would help
im sure killab will chime in
2005 SRT 4 ACR
INJEN CAI, MOPAR CATBACK, MOPAR STS, PROHANE MOTOR MOUNT(RACE), ENERGY BUSHING KIT
mayhem is offline
post #2 of 31 (permalink) Old 10-02-2012, 10:50 PM
KillaB's Avatar
Quoted: 1 Post(s)
Pretty much we researched about everything to do with the cylinder head.. We tried the cam cap "fix" only on the exhaust side. well it didnt do anything to improve noise.
We used a makeshift mechanics stethoscope to listen around the engine to determine where the noise is coming from. nothing from the bottom end. Popped the valve cover and noticed the groove on that part of the exhaust cam lobe while doing the cam cap fix. very smooth and straight line. Cant feel with your finger or finger nail.
So now we are lost, and need a direction to turn with the how to fix. Like he said idle cant hear the noise, rev to 2k-4kish you can hear the noise while driving or sitting still. no noise while in boost.
We are not rich and famous so we want to try all the home remedies before going in to a shop. Im not a "pro" but know my way around a car and how to handle a few wrenches from various repairs and engines swaps in my life.
Any help so He can stop texting me all hours of the day about it? haha
as for his mods, nothing internal. 99% stock car
2003 Solar Yellow
12.79 @108.23
KillaB is offline
post #3 of 31 (permalink) Old 10-03-2012, 03:31 PM
Malevolence's Avatar
Quoted: 0 Post(s)
Try moving the lifters/rockers from that cylinder to another cylinder and see if the noise follows. Then you'll know if it's to do with that or valvetrain.
Malevolence is offline
post #4 of 31 (permalink) Old 10-03-2012, 03:33 PM
Quoted: 0 Post(s)
I probably have thousands of OE lifter/rocker sets lol, if that's what it turns out to be just send me a PM and you can have them for shipping cost.
post #5 of 31 (permalink) Old 11-26-2012, 09:30 PM Thread Starter
mayhem's Avatar
Quoted: 0 Post(s)
I'm bumping this back up. I have yet to figure it out and dodge wants a arm and leg to check it out.
Thanks for the help
2005 SRT 4 ACR
mayhem is offline
post #6 of 31 (permalink) Old 11-26-2012, 10:24 PM
srtmike04's Avatar
Quoted: 85 Post(s)
malevolence just suggested how to start a diag on it. that would be the easiest cost effective process to start with
srtmike04 is offline
post #7 of 31 (permalink) Old 11-28-2012, 12:36 AM
Quoted: 0 Post(s)
Rob on that cam is in an actual grove? can u feel it pit in with ur finger nail that doesn't look like anything out of the ordinary.
ForBidden is offline
post #8 of 31 (permalink) Old 11-28-2012, 12:40 AM
KillaB's Avatar
Quoted: 1 Post(s)
If I remember correctly you could not feel it with a finger nail. Looks like some what normal wear.... He got lash adjusters from the guy above and had the same wear.
He still hasn't tried to replace the lifters/rockers.
2003 Solar Yellow
12.79 @108.23
KillaB is offline
post #9 of 31 (permalink) Old 12-01-2012, 02:10 PM
Quoted: 0 Post(s)
most of the time whan you kill the cylinder/remove spark plug wire and the noise goes away its the bottom end like a wrist pin or rod bearing.
Billy172 is offline
post #10 of 31 (permalink) Old 12-01-2012, 02:36 PM
atroph's Avatar
Quoted: 209 Post(s)
Garage
+1 for what Billy has said. I had an engine that had a "ticking" noise at around 2K+ rpms. Removed #2 spark plug and it went away. Figured it was a wrist pin until I pulled the pan. Had a piece busted out of the bedplate between 3 and 4.
I would try swapping the lifters and adjusters around and see if the noise moves. If not then pull the pan.
atroph is offline
post #11 of 31 (permalink) Old 12-01-2012, 03:36 PM
Quoted: 0 Post(s)
atroph how much hp did you have whan you broke that bedplate and what are you mods thanks
Billy172 is offline
post #12 of 31 (permalink) Old 12-01-2012, 06:53 PM
atroph's Avatar
Quoted: 209 Post(s)
Garage
Well I bought the car like that. In theory it was set up for around 500hp. It had serious tune issues and running lean/hot. The pistons were slightly melted on the edges.
Mods were:
Wiseco's .020
Eagle Rods
GT35R Turbo
BC Stg 2 Cams
Eagle Rods
Siemens Deka 80lb Injectors (Mustang??) (They would reach static PSI at 15lbs of boost)
AEM EMS
I am in the process of a full rebuild as only the rods were salvageable from the bottom end.
Sorry to thread jack OP. Free bump for some more answers.
atroph is offline
post #13 of 31 (permalink) Old 12-01-2012, 07:49 PM
KillaB's Avatar
Quoted: 1 Post(s)
After he put on 9k miles with driving hard/ racing with this "tick" wouldn't a bearing or wrist pin give by now
2003 Solar Yellow
12.79 @108.23
KillaB is offline
post #14 of 31 (permalink) Old 12-01-2012, 08:24 PM
atroph's Avatar
Quoted: 209 Post(s)
Garage
Not necessarily. It could have knocked once and set something slightly askew. Might not be able to see by visual inspection. Either way I would pull the pan for piece of mind at next oil change. Its not that hard to do, and could yield lots of info.
atroph is offline
post #15 of 31 (permalink) Old 12-02-2012, 08:46 AM
Quoted: 0 Post(s)
if he drove/race for 9k I would say its the wrist pin, bearings would have gone by now. what are the mods on the car. thanks atroph i have some more ? I will pm you thanks.
Billy172 is offline
User Tag List
Linear Mode Linear Mode
