Old 07-17-2008, 12:40 PM   #1 (permalink)
all_motor_mike's Avatar
Member Number: 43287
Default the difference in rocker arms........
(pics are courtesy of jeffb on the org.)
well here are some pics showing the difference between the three different rocker arms. as u can see the neons are a bit weaker on the back half compared to the other 2, on the pt/srt they redesigned the back half and made it bit more beefier so there would be a lesser likelyhood of them breaking off, and on the 2.7 they just redesigned the oil hole that sits on the lifter and made it face the cam lobe and rocker roller for better lubrication. the 2.4s are fine but if u want that little bit more peace of mind on ur high hp/ rpm build then i would definitely go with the 2.7 rockers.
mike
all_motor_mike is offline   Reply With Quote
Old 07-17-2008, 03:39 PM   #2 (permalink)
matthew00029's Avatar
Member Number: 46349
Nice write up...good info
05 Black SRT-4 ACR A lot of hard work and broke days. I hope someday the black beast will return...
matthew00029 is online now   Reply With Quote
Old 07-17-2008, 11:34 PM   #3 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
Just dont let DCR see it, lol
Project log pics
Old 07-17-2008, 11:55 PM   #4 (permalink)
why do you say that?
Old 07-17-2008, 11:56 PM   #5 (permalink)
Hold on I'll get the link, put it this way, the more I learn and know, the more I find DCR to be not as great.
I'm upgrading my head and need some advice
Old 07-18-2008, 12:24 AM   #6 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (29)
do the 2.7 rockers drop in?
JnR Performance=envied by many in norcal
Sponsored by DCR
for sale:
mopar short shifter 80 shipped obo
reed32 is offline   Reply With Quote
Old 07-18-2008, 01:13 AM   #7 (permalink)
Yes, and tips of the lifters are the same size as are the cups on the rockers, so what DCR said makes no sense when referring to "wear in the pivot cup area over time".
Put it this way , I would not waste my time thinking its going to gain anything, but if you getting new rockers then sure get these instead. But also it will help keep oil out of the head/vc area so could reduce oil in the pcv system. The sealed power ones from rock auto were cheapest last I knew or moparsupercenter for mopar.
Heres some better info:
www.neons.org :: View topic - 2.0 Dohc Rockers & lifters and why to replace(upgrade).
www.neons.org :: View topic - Be wearry of the 2.7L rockers
I have them in mine and no issues
Old 07-18-2008, 12:42 PM   #8 (permalink)
Member Number: 2096
... put it this way, the more I learn and know, the more I find DCR to be not as great.
xmdfmk7x is offline   Reply With Quote
Old 07-19-2008, 02:51 AM   #9 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (29)
so get the n/a pt rockers with 2.7 lashers?
wouldn't the pt's have the same rockers as the 2.4 srt4?
Old 07-19-2008, 03:42 AM   #10 (permalink)
no no no, the 2.7 lashers are almost twice the size of ours but the rockers are the same. u want the 2.7 rockers and the pt/srt (n/a or turbo the lashers are the same) lashers because they have the hole in the top unlike the 95-00 lashers found in the 1gn neons and other cloud cars with dohc engines.
mike
Old 07-19-2008, 07:55 AM   #11 (permalink)
2mopar's Avatar
Member Number: 25391
Trader Rating: (24)
I was told by dcr to use the stockers over the 2.7's also...
2mopar is offline   Reply With Quote
Old 07-19-2008, 07:58 PM   #12 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (29)
mike
got it! that will be added to my list
Old 08-17-2008, 12:01 AM   #13 (permalink)
Bebo's Avatar
Member Number: 46331
Question
If you run the 2.7l rockers could you still use the oil restrictor/mod? I was wondering because the oil restrictor/mod is to prevent lifter pump-up but, the 2.7l rockers redirect the oil flow to reduce oil pooling in the head & provide better cam lubrication. Can they be used together or will they restrict the oil flow too much? I know they do different things in reguards to oil flow but, have simliar effects.
The global warming issue with carbon is complete BS. Volcanoes put out more carbon in a week than the human race ever has in it's entire existance. If you don't believe me, there are volcanoes erupting every day & here is my proof of that: http://hisz.rsoe.hu/alertmap/index.php?lang=eng
Bebo is offline   Reply With Quote
Old 08-17-2008, 02:29 AM   #14 (permalink)
Member Number: 41700
so this would just provide better cam oiling properties, could you mod the oil relief on the 2.4 rockers to do that without taking the chance on a mismatch set
I CRUSH DREAMS FOR A LIVING
Old 08-17-2008, 09:18 AM   #15 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (62)
interesting..
SCT Tuned by Kevin@AGP Turbo
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
