Old 06-20-2008, 11:02 PM   #1 (permalink)
1QKSrt4's Avatar
Member Number: 56257
Default DCR 5 layer head gasket install
I picked up a 5 layer head gasket from a friend of mine and just asking to see if there is any special things i need to do for installation other than just toss it on and torqued the head down correctly. Anybody know? thanks
HATED............
1QKSrt4 is offline   Reply With Quote
Old 06-21-2008, 08:57 AM   #2 (permalink)
Member Number: 64760
Trader Rating: (12)
im assuming you bought new headstuds.
headstuds arent reusable.
91PumpKing. is online now   Reply With Quote
Old 06-27-2008, 10:34 PM   #3 (permalink)
Member Number: 42667
head BOLTS are reusable as long as the threads arnt necked down.
im sick and tired of saying this so many times.
LOOK IN THE SERVICE MANUAL.
05plsrt4 is offline   Reply With Quote
Old 06-30-2008, 02:15 PM   #4 (permalink)
bryant's Avatar
Member Number: 6232
the instructions say to spray the gasket with some high temp engine enamel paint stuff, Or there is the normal dodge gasket sealer stuff. I am not sure what is the best method. Also not sure how dry you let it get before you put it on.
bryant
2004 e-blue nsrt4 stage 3
2008 silver csrt4 stage 0
bryant is offline   Reply With Quote
Old 06-30-2008, 02:22 PM   #5 (permalink)
there is normal Chrysler gasket spray thats pretty awesome stuff.
The gasket spray helps seal small imperfections in the cylinder head and engine block. First came out when the 1 gen neons had all the head gasket problems. Helped seal up all the pitting from corrosion.
Old 06-30-2008, 02:23 PM   #6 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (15)
I used copper gasket on mine (the spray kind) on both sides. Same shit I use for exhaust gaskets, too. Just make sure the top of the engine is spotless and there's NO old gasket material left and torque down according to the FSM and you'll be golden.
I love turbo lag, it gives you a second to reflect about the poor decision you have just made.
Old 06-30-2008, 02:40 PM   #7 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (391)
Stock uses headbolts...not headstuds.
Also headbolts are reusable and headstuds are CERTAINLY reusable.
Honestly though, the stock headbolts are very cheap. If they have been on there for awhile, I would get new ones.
10.62@133.8 '05 SRT-4 Neon
11.87@125 '08 SRT-4 Caliber
Worlds Quickest/Fastest CSRT-4
Old 06-30-2008, 02:55 PM   #8 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (15)
true dat
arp head studs are designed so that you can reuse them many times. Even with 85ft\lbs of final torque, is only about 70-75% yield strength of the fastner.
I got's a fuel cell......................what you got?
Don't call it a comeback..........Thug Life
DDogsrt461BLK 3.0 is online now   Reply With Quote
Old 06-30-2008, 03:00 PM   #9 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (17)
Get all the old crap off with a green pad or something. Don't use a flapwheel. If you have to scrape anything don't use a metal scraper. Get a plastic one. Clean it real good with Brakleen. Then I too used copper spray on gasket maker. The Mopar stuff is good to so I hear but I ddn't feel like fucking with the dealer. Make sure you follow the torqueing procedures to a T for the headstuds/bolts w/e the fuck you want to call them.
HCCAFan is online now   Reply With Quote
Old 06-30-2008, 09:50 PM   #10 (permalink)
1QKSrt4's Avatar
Alright i threw it on with new stock head bolts and torqued it up to specs, but i didnt know about the copper gasket spray. Am i gunna be good if i didnt use it??
Old 06-30-2008, 10:29 PM   #11 (permalink)
ritfordprobe's Avatar
Member Number: 53609
The FSM says to use the spray. It may seal without it, but I would certainly use it. We recently pulled the heads off of an LS1 that we just put the spray on, and it was like glue. It really helps seal up any imperfection that may be there.
'03 SRT4 - 11.930 @ 119.68 - first pass with the new slicks
--My Mod List--
ritfordprobe is offline   Reply With Quote
Old 07-01-2008, 09:42 AM   #12 (permalink)
HCCAFan's Avatar
Trader Rating: (17)
If you torqued it right I think you will be OK. What are your horsepower goals?
Old 07-01-2008, 10:59 AM   #13 (permalink)
1QKSrt4's Avatar
Only like mid 400's i have a big wheeled stg 3
Old 07-01-2008, 11:16 AM   #14 (permalink)
HCCAFan's Avatar
Trader Rating: (17)
Might be kinda stressful for no gasket and stock head studs. If it wasn't too big a deal I would go head and spray the gasket stuff on there. If it's all back together, you gotta borrow tools and a garage...I'd say fuck it.
Old 07-03-2008, 07:34 PM   #15 (permalink)
Member Number: 60965
we just installed a new dcr head gasket and new arp head studs @ 85 lbs, but put it on dry without applying the spray on sealant. The head had a skim cut taken off the bottom at the machine shop when we had it pressure tested. Havent put anything else back on yet. assume that i cant unbolt and spray now without buying new gasket? should I just leave as is and hope for best?
strtrcer00 is offline   Reply With Quote
Page generated in 0.29226 seconds with 11 queries
