Old 09-09-2009, 07:28 PM   #1 (permalink)
Member Number: 70258
Trader Rating: (12)
Default Crane 18's
Ok since nobody wants to buy them from me I may end up using them. My ? Is are they going to be worth it when combined with my current mods? Right now I have an agp cai,Hahn s20g,custom tubes Inc charge pipe,agp hard pipes,cca bfmic,ported stock tb,3" tbe,mpx udp,agp dogbones/tranny mount,mopar 3bar map/tip sensors,dsp,spec stage 3 clutch,fidinza aluminum flywheel,750cc dw injectors,255 walboro fp,fp rewire and tps rewire. Mode I'll be doing regaurdless if I do cams dcr oil modifier,greddy profec b ebc,aem uego,boomba sts,b-woody traction bars and progress f sway bar. Mods if I do cams fidinza gen 2 cam gears,bc springs/retainers and the crane 18's. My head is stock and so is my intake. Will I be able to run this combo and it still run good?
79 Buick Regal 360ci sbc 13.70 @102 n/a so far
97 Trans Am WS6 LT1 11.94 @112.26 n/a with a 1.603 60ft
04 Mustang GT Bolt-ons 13.35 @102.43 n/a more parts soon
04 SRT-4 20g and bolt-ons 13.28@110 with a 2.21 60ft best mph run 13.42@113.5 with a 2.37 60ft on just 20psi
Blackbird1084 is offline   Reply With Quote
Old 09-09-2009, 07:48 PM   #2 (permalink)
d_fl8ted1's Avatar
Member Number: 11549
Trader Rating: (81)
Whats the lift and duration of these cams.... i have some crower stage 2s... i want to go bigger... maybe a trade?
On the 8th day GOD created drag racing
d_fl8ted1 is offline   Reply With Quote
Old 09-09-2009, 08:04 PM   #3 (permalink)
Trader Rating: (12)
Dur @ .050 is 216/216 lift is 394/394 on a 112 lsa. What is it on the cs2's? Are they cs2's or bcs2's?
Old 09-09-2009, 08:06 PM   #4 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
they are the crower stage two cams... not sure if yours are bigger then mine or not
Old 09-09-2009, 08:09 PM   #5 (permalink)
ppx
Member Number: 39388
Trader Rating: (68)
the crane 18s are in the middle of crower s2 and crower s3's
ppx is offline   Reply With Quote
Old 09-09-2009, 08:11 PM   #6 (permalink)
matthew00029's Avatar
Member Number: 46349
Trader Rating: (21)
18's are bigger but only slightly....
To OP, I don't see them helping you but thats just my opinion. I think you need ported head and intake to really benefit from the 18's.
How much were you asking for them?
05 Black SRT-4 ACR Almost there
matthew00029 is offline   Reply With Quote
Old 09-09-2009, 08:18 PM   #7 (permalink)
Trader Rating: (12)
$400 shipped but I stated many times that I was open to offers. What cams then would go best with my setup as I don't know how long it'll be before I'll be able to get a ported head.
Old 09-09-2009, 08:26 PM   #8 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
well i guess i will just need to sell mine and go with the bc stage 3s...
Old 09-09-2009, 08:31 PM   #9 (permalink)
Trader Rating: (21)
I hope you meant crower stage 3's. The BC s3's are pretty much the same thing as you got. Not worth the change.
Old 09-09-2009, 08:36 PM   #10 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
yeah my bad... didnt mean to put that in there... i mean just the crower stage threes...
Old 09-09-2009, 08:45 PM   #11 (permalink)
Trader Rating: (21)
Just making sure!!
So are you keeping your gt40 or going a different route?
Old 09-10-2009, 03:44 AM   #12 (permalink)
porksword's Avatar
Member Number: 66925
Trader Rating: (21)
Crower stage 2s are Dur@.050 is 208/203, gross lift is .385/.382
porksword is offline   Reply With Quote
Old 09-10-2009, 07:38 AM   #13 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
Just making sure!!
I am considering going with a borg warner turbo... but not made up my mind yet...
Old 09-10-2009, 09:39 AM   #14 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (73)
To the OP, 18's on a 20g wont help you any. They will be more of a hassle to put on than running them.
Sell them for what ever you can get out of them and buy a better turbo if you want to go faster. If your in the 20g range(45-55lbs) then buying a better turbo is the best choice at going faster.
supermech21 is online now   Reply With Quote
Old 09-10-2009, 11:07 AM   #15 (permalink)
Trader Rating: (12)
A turbo isn't gonna be as cheap as a set of cams. Also I'm just shooting for high 11's @120+ which I should be able to get with the 20g. I'm already traping 113's peddaling the crap out of it peaking 23psi and holding 20 to redline. I should reach my goal running 28 psi on race gas.
Page generated in 0.19902 seconds with 13 queries
