compression test good or bad? - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-21-2012, 01:13 PM   #1 (permalink)
Member Number: 62465
Default compression test good or bad?
ok so yeah i did a compression test today on a stock bottom end car with stage 2 bc cams /mpx gears and bolt ons with a zeta 2.8 turbo kit it read 160 180 180 180? is this good or bad and do i have a problem with a vlave ? or whats going on with it it runs good besides idle is rough unlike most cars with cams i have seen the car is un-tuned still also so who knows
speedypollard is offline   Reply With Quote
Old 11-21-2012, 01:26 PM   #2 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
i think the rule of thumb is u dont want more than 10% difference....
looks like 11.1111111%
Old 11-21-2012, 03:20 PM   #3 (permalink)
DeAnzaJig's Avatar
Member Number: 87711
theres no way to tell exactly where the leakdown is until you do a LEAKDOWN TEST.
How To Perform A Leak Down Test - EricTheCarGuy - YouTube
Heres a good video of how to do one. or if you wanna do another test, whatever cyl is 160, pour a little oil into the cyl and do the compression test again. that will tell you weather or no its a ring issue. if compression raises significantly, its a ring problem. if not, then its either your head gasket, or a valve
DeAnzaJig is offline   Reply With Quote
Old 11-21-2012, 04:34 PM   #4 (permalink)
Default ?
could it be possible nothing is wrong or not bad enough anyway with out removing head or timing components possibly cam gears need adjusted ? idk just guessing
Old 11-22-2012, 12:07 PM   #5 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
If the car is untuned, that is more then likely your reason for the rough idle.
Retest the low cylinder.
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 11-22-2012, 12:29 PM   #6 (permalink)
Member Number: 91222
did u do a dry test or wet test? it sounds fine your almost within the 10% tolerance i just did mine 165 across the board with 97k on stock motor
didlewine is offline   Reply With Quote
