Can I use these ports for sending units? Pros/Cons
So I have my SRT torn down for some port work and basic clean up and engine detail. On the back side of the motor, where the stock oil pressure sending unit is, I used brass fittings to make a system to hold my Stock Oil Pressure Sender, Autometer Oil Pressure Sender, and Autometer Oil Temp Sender. While it worked, I really thought it was pretty crappy to look at an at some point would probably leak oil (as there were just so many fittings). With most things removed from the engine bay I kept looking at the two plugs on the drivers side of the head. I assume I can unplug these and use them for oil related needs, but I wasn't sure...so I'm turning to my friends here on SRTForums for help. LMK if I can use these ports, and if so, what are the pros and cons behind using them.
i have tried both the sender in the oil pan and in the head. have not tried the block fitting,although all are pretty good spots. i have mine in the head. the oil pressure readings are a bit different form the block and head,but not too much.
I was thinking of using the rear port (on the head, in my pic) for oil Temp, then just using the rear stock pressure port for both the OEM sender and the Autometer Sender.
Does anyone know what thread size the head ports are?
