Old 09-05-2009, 07:50 PM   #1 (permalink)
2003srt-4's Avatar
Member Number: 67241
Trader Rating: (37)
Default camshaft caps torque spec.
ok did the oil flow modifier and read the how to on it but when it comes to torquing the cam cap down it dont give me a torque spec just a n,m and my torque wrench dont got that it just gots torque only.so if someone would tell me what spec to torque the (2) 10mm bolts and the (1)8mm bolt i would appreciate it.thanks
50trim..,AEM intake,hks bov,
mpx 62mm TB-agp shift selector
balance shaftchain removed-charge pipe mode
act 6-puck clutch w/prolite weight flywheel
quickwhips IC-hondata heatshield/gasket
bwoody h-brace,traction bars
3''TBE,wot box/2-step,180 stat,fan switch mod
hurst sts/booger bushing/msd coil/wires-safc neo,walbro 255lph,fuel pump rewire
s2 injectors, returnline,boomba fuel rail.dcr oil modifier,agp solid mm and trany mount.
2003srt-4 is offline   Reply With Quote
Old 09-05-2009, 08:09 PM   #2 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
To convert in/lbs to ft/lbs divide by 12.
So for the 8mm bolt 105in/lbs12 = 8.75ft/lbs.
the 10mm bolts 250in lbs/12 = 20.83ft/lbs.
Old 09-05-2009, 08:13 PM   #3 (permalink)
2003srt-4's Avatar
Trader Rating: (37)
ok thank you for the help on that!!i appreciate it.
Old 09-05-2009, 08:18 PM   #4 (permalink)
AdvanSRT-4's Avatar
Trader Rating: (57)
Old 09-05-2009, 08:34 PM   #5 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
good job eric
AGP S256 FS
Page generated in 0.12410 seconds with 13 queries
