im in the process of getting my head ported.. what cams do you guys think i should use.. bc stage2, stage 3, crane 14, or crower 2s?? along with matching springs and retainers... is it that important to get aftermarket intake and exhaust valves?? or would stock be fine??
im using a agp 60 trim with 750cc injectors, fidenza gears, dtec fcbc to tune and all the supporting mods.. stock block
just not sure which is the best way to be able to still use it on the street and enjoy driving it.. looking for maybe 450whp area
I want a 2.0 dohc intake cam
and a .285 lift exhaust custom cam.
Why, because I'm crazy, and with a 6500rpm limit, that's the most lift to street ability, vs port runner volume. Trust me!!! I used a hydroponic math equation to figure it all out.
a standard rebuild w/ an overbore and now magically, its the best 2.5 ever.
get over it.
where do you get this best ever shit?
It's a .020 over piston, stock stroke
don't be pissed at me, because I decided to build a engine. Just like I decided to spray nitrous, on HOM because I have a different vision then yours, no need to diss.
All I will say, is the next video I post will do all the talking. It's going to be a monster. I didn't just do a bore & hone, there plenty of other goodies going into this project.
Yep stil have stock rev 62-6300... starting to lean towards the crane 16s now.. Hmm
So would bc stge 3s give me more top end only if I was rev @ 7k?
I'm planning to do ems laterr on so I was told that with crane 16s the could still work for higher rev down the road like when I decided to upgrade to ems
Are crane 16s equivalent to bc stage 2s?
Or slight bit bigger?
if your using the stock valves i would go with 14's /16's if your realy gona push it , just remember the more cam= the more low end torque you sacrifice
autometer egt probe new 40
stock gauge w/stock pod 30
mallory 6al ignition 75
