Old 05-01-2008, 11:38 PM   #1 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (18)
Default Cam Gears go which way?
Apparently the Fidanzas have two slots for the nipple on the end of the cams so you can mount the gears so the nipple is up top with the 0 degree mark on the gears or you can do it 180 degrees the other way so that the nipple is down then the 0 degree mark is at TDC. Which way is it supposed to go? I got a bad feeling the nipple is down at TDC after looking at the stock cam gears again.
HCCAFan is offline   Reply With Quote
Old 05-02-2008, 12:09 AM   #2 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
Bedtime bump!
Old 05-02-2008, 12:23 AM   #3 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (17)
That's so it can fit on any cam. The end of your cams, have dowel pins. When disassembling the engine, on mine, both sat at the bottom, when ATDC. Other cams, the dowel pin might point up, instead of down. Hence the reason why they have the slots. Either way, if the dowel pin sits up or down, ATDC, these cams will allow you to get the proper timing markings lined up correctly. They fit both, you dig?
Stg3 toys, ported head & intake, NX 4nozzle, progresser, wide ban, egt, fuel pressure, injen, samco, Mpx3", Maxxfab02,Greddy CC, Boomba's, AIS intercooler, STS, billet SS, .020 8-1 JE's, Eagle 4340 H beam rods, UDP, you name it I've done it Mopar Clutch
Don't be messing with my FJO!!!!
2 180+ Lph pumps feeding the bitch!!!!
DDogsrt461BLK 3.0 is online now   Reply With Quote
Old 05-02-2008, 12:33 AM   #4 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
Yeah. So how can I know which way is TDC? These are Crane 16 cams and I think they are the same as the factory cams. The factory ones have the pins downwards at TDC don't they?
Old 05-02-2008, 05:19 AM   #5 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
UH put the cam holes UP and the gears UP(unless you want them upside down for some reason) and crank at TDC, its not hard
Project log pics
Old 05-02-2008, 10:20 AM   #6 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
I'm not asking how to set the timing. I'm asking which way the gears go on the ends of the Cams. What "holes" are you talking about? I believe you are saying the opposite of DDog.
Old 05-02-2008, 12:51 PM   #7 (permalink)
you put the holes in the cams facing UP(so have the VC off to make sure)
then you put the gears on however you wish, most people put the adj numbers at the top because that makes sense.
Its not hard, theres even a sticky at the top of this area w/ pics
Old 05-02-2008, 06:16 PM   #8 (permalink)
HCCAFan's Avatar
Trader Rating: (18)
Yes, the cam holes on the cam itself next to the lobes point upward. Got it. One gear had to be 180 degrees off from the other to make this happen.
Page generated in 0.18177 seconds with 11 queries
