Old 08-27-2009, 11:33 PM   #1 (permalink)
Matts04SRT's Avatar
Member Number: 58076
Default BC retainers
I was just wondering for those that have them, how hard were they to get off to say replace the valves with bigger ones? If you did remove them how did you do it? I am triing to get mines off to install my +1mm valves but cant seem to get the retainers off. Any help plz
04 Silver NSRT-4: 303whp & 388tqr S2+racegas+meth
New setup: have yet to see
Matts04SRT is offline   Reply With Quote
Old 08-28-2009, 09:05 AM   #2 (permalink)
GreaseMonkey69's Avatar
Member Number: 43017
Trader Rating: (23)
do you have a valve spring compressor? you need to compress the valve springs enough to get the valve keepers off of the valve stem. then after that you can remove the retainer and the valve spring... if your going to install 1mm over size valves you have to have work done on your valve seats to accommodate the larger valves. i would say get the machining done for the 1mm over size valves might as well get a 3 angle or 5 angle valve job too. get some new stock valve seals too. it wouldn't hurt
GreaseMonkey69 is offline   Reply With Quote
Old 08-28-2009, 05:47 PM   #3 (permalink)
Matts04SRT's Avatar
Yea where I am doing it has the compressor, and yea I know to get the seats cut thanks, actually it already has new seals I had the head rebuilt not to long ago, like maybe a few month. And I am getting a job done to both the seats and valves Thanks for the help
Old 08-29-2009, 12:29 PM   #4 (permalink)
Matts04SRT's Avatar
Anyone know of a place that sells a spring compressor for the DOHC's?
Old 08-29-2009, 09:18 PM   #5 (permalink)
julius717's Avatar
Member Number: 24352
you can get a spring compressor anywhere just go to kragen or pepboys or napa where ever an auto parts store is
DRASTIC
julius717 is offline   Reply With Quote
Old 08-30-2009, 07:11 PM   #6 (permalink)
Matts04SRT's Avatar
We called around and everyone had just regular compressor but none that would work for the DOHC set up. I got them off, I just used a hammer and a socket, hit them a few times and the locks came out. The machine that my dad was using wasnt pushing them down far enough due to the BC springs being stiffer. But its all apart now and hopefully by thurs Ill have my car back up.
Old 08-31-2009, 10:15 PM   #7 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (204)
is JD doing your install?
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity
For SoCal guys only! Now offering JD-M Specials!
Old 09-01-2009, 06:25 PM   #8 (permalink)
Matts04SRT's Avatar
Nope I am, ive done all my work, but in some cases have gotton help from JD
Page generated in 0.17626 seconds with 13 queries
