Might be hard to get a good answer on this one. most guys that took the head off either had a problem to start with, had it ported, did an engine rebuild, or at least did cams at the same time.
I would like an answer to this as well since I just put in oversize valves also, but it might be hard to get a good answer.
The way I looked at it is, there are 8 exhaust valves and 8 intake valves. So with +1mm valves I gained 8mm of air flow on both intake and exhaust. At 20-30psi just think of how much air you can flow through an 8mm socket if it was attached to your air compressor. Might not be HUGE but every little bit helps.
