Old 05-21-2008, 07:20 PM   #1 (permalink)
Member Number: 64119
Default ALL cam specs...and tuning stuff.
bringing it back. hopefully these damn kids will read the specs and the info and stop askin the same damn questions each week.
ill re-add the tuning stuff later.
SRT-4
duration @ .050: 172/175
Valve Lift: .327/.261
LSA: 113
2.0L Neon
duration @ .050: 174/173
Valve Lift: .347/.315
LSA: 110 int: 108 exh: 112
DOHC 2.4 N/A
Duration@.006": 232/240
LIFT: .324/.256
LSA: 113 intake: 115 exhaust: 111
please note, the duration is not anywhere near correct in terms of in correlation to the .050" ratings...
Brian Crower
Stage 2
duration @ .050: 186/184
Valve Lift: .350/.310
Stage 3
duration @ .050mm: 194/186
Valve Lift: .389/.383
Crower 2.4
Stage 1
DURATION @ .050: Int: 186°/Exh: 184°
Valve Lift:Int:.357 / Exh:.308
Stage 2
DURATION @ .050: Int: 208°/Exh: 203°
Valve Lift: Int: .385 / Exh: .382
Crower 2.0
stage 1
duration @ .050: 197/197
Valve Lift: .383/.383
stage 2 (Nitrous cam)
duration @ .050: 196/196
Valve Lift: .403/.403
Stage 2 (Forced induction Cam)
Valve Lift: .416/.410
Stage 3 (street/strip cam)
duration @ .050: 204/204
Valve Lift: .410/.410
Stage 3 (Race Cam)
duration @ .050: 210/210
Valve Lift: .420/.420
CRANE CAMS
10s
duration @ 1mm: 200/200
Valve Lift: .354/.354LSA: 110
12s
duration @ 1mm: 204/204
Valve Lift: .364/.364
LSA:112
14s
duration @ 1mm: 204/196
Valve Lift: .364/.354
LSA: 110
16s
duration @ 1mm: 208/208
Valve Lift: .374/.374
LSA: 110
18s
duration @ 1mm: 216/216
Valve Lift: .394/.394
LSA: 112
WHICH CAMS NEED VALVE SPRINGS:
BC 3s
Crower 2.4: stg2s
Crower 2.0: stg1 and up
Crane 16's and larger
all else are fine w/ stock springs
VALVE SPRINGS:
Crane Valve Springs
Outside diameter: 1.065
Inside diameter: 0.725
Seat pressure: 60lbs@1.535
Open pressure: 255lbs@1.063
Coil bind: 0.987
Rate: 413
Maximum net lift: 0.472
Brian Crower Valve Springs
Seat Pressue: 1.500" @ 92 lbs
Open Pressure: 1.100" @ 195 lbs
Coil Bind: 0.920"
Ferrea Valve Springs
Stage 1
S10107 Dual Spring
Inside diameter: 20.8 mm
Outside diameter: 28.0 mm
Seat Pressue: 90lbs@37mm
Open Pressure: 200lbs@27mm
Rate Inch: 279lbs
Coil Bind: 23mm
Max Net Lift: 12mm
Stage 2
S10108 Dual Spring
Seat Pressue: 105lbs@37mm
Open Pressure: 235lbs@27mm
Rate Inch: 330lbs
Coil Bind: 23.5mm
Max Net Lift: 12mm
The Stage 1 and 2 spring requires Ferrea Titanium Retainer #E11074 and BOTH, Ferrea spring seat locator # SL1062 and factory supplied spring seat locator.
SOHC Crane Springs in the DOHC head
Outside Diameter: 1.065
Inside Diameter: 0.725
Seat Pressure: 85lbs@ 1.535
Open Pressure: 244lbs@ 1.135
Coil Bind: 1.014
Rate: 397
Maximum Net Lift: 0.440
DCRValve Springs w/ Moly Retainers
120lbs @ 1.535 @ base
290lbs @ 1.035 @ max lift and .060 from coil bind.
10,000 rpm tested at over 65lbs of boost!
$300 set
MANLEY PERFORMANCE
Outer Diameter: 1.100"
Inner Diameter: .775"
Seat Pressure: 92lb@1.5"
Open Pressure 188@1.175" 237@1"
Max Lift: .500
Coil Bind: .950
Santiago. is offline   Reply With Quote
Old 05-21-2008, 07:21 PM   #2 (permalink)
Reserved.
Old 05-21-2008, 07:22 PM   #3 (permalink)
______
Old 05-21-2008, 07:22 PM   #4 (permalink)
Buy/Sell Section Moderator
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (131)
Reserved for cat pics.
12.1 @ 125.8 mph on street tires & pump gas
Old 05-21-2008, 07:24 PM   #5 (permalink)
kitty pr0nz is in SOT mister!
Old 05-21-2008, 08:04 PM   #6 (permalink)
lilmike0450's Avatar
Member Number: 56278
Def. sticky this plz...
05 White ACR
lilmike0450 is offline   Reply With Quote
Old 05-21-2008, 08:17 PM   #7 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (20)
Here are the only Cam spec timing cards I found on the Crane website.
Crane 12's
Lift: Intake @Cam 5.32mm @Valve 9.25mm All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 5.32mm @Valve 9.25mm
Rocker Arm Ratio 1.737
Cam Timing: VALVE @.15mm
Lift: Opens Closes ADV Duration
Intake 14.0 BTDC 52.0 ABDC 246.0 °
Exhaust 58.0 BBDC 8.0 ATDC 246.0 °
Cam Timing: VALVE @1.0mm
Lift: Opens Closes Max Lift Duration
Intake (3.5) ATDC 34.5 ABDC 109 211.0 °
Exhaust 40.5 BBDC (09.5) BTDC 115 211.0 °
Crane 14's
Exhaust @ Cam 5.03mm @Valve 8.76mm
Rocker Arm Ratio 1.740
Intake 18.0 BTDC 48.0 ABDC 246.0 °
Exhaust 54.0 BBDC 4.0 ATDC 238.0 °
Intake 0.5 BTDC 30.5 ABDC 105 211.0 °
Exhaust 36.5 BBDC (13.5) BTDC 115 203.0 °
Nigel
04 Srt-4-50 trim, Crane 14s, 635's, Dtec, etc
88 Civic-D15 mini me, full exhaust, weight reduction
Soon to be powered by DIABLO SPORT!
Installs, tuning, and tranny rebuilds done in NC! PM me NOW for GREAT pricing!
http://www.trudynosports.com/customers/nigel.html
Old 05-21-2008, 08:28 PM   #8 (permalink)
thanks bro. ill add them.
Old 09-18-2008, 12:58 PM   #9 (permalink)
foxracing12002's Avatar
Member Number: 45389
Trader Rating: (20)
sooooo, the NA 2.4l cams are pretty decent size???
anyone try them??
Ruthless.
TRACTION PWNS ME!!
ANTI-SWEETS CLUB MEMBER # 2
foxracing12002 is online now   Reply With Quote
Old 09-18-2008, 06:42 PM   #10 (permalink)
Member Number: 64760
Trader Rating: (17)
please dont.
91PumpKing. is online now   Reply With Quote
Old 09-19-2008, 09:24 AM   #11 (permalink)
Trader Rating: (20)
Quote: Originally Posted by 91PumpKing. View Post
please dont.
oh i already did. i keed.
so the 2.0's like ret exh???
Old 09-24-2008, 03:04 PM   #12 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (60)
where can i find crane 14s, who sales them
thats fantastic
AGP S256 + B&G FLASH
FS STOCK HEAD 150 shipped
Old 09-24-2008, 03:08 PM   #13 (permalink)
Trader Rating: (17)
please dont get those either.
coors...best bet is modernperformance
Old 09-24-2008, 03:11 PM   #14 (permalink)
lyncoo's Avatar
Trader Rating: (60)
thanks your allright no matter what reed says about ya
Old 09-24-2008, 03:50 PM   #15 (permalink)
Trader Rating: (17)
reed hatin'!?!
» Search Used Cars
