Old 06-11-2008, 08:51 PM   #1 (permalink)
aww sheet's Avatar
Member Number: 20431
Default 5 layer headgasket
ok headgasket is gone.
dcr or tk motorsports? tk is cheaper, and they sell an upgraded timing belt as well, so i'm leaning towards them.
on a side note, i'm gonna go ahead and install my 2L cams, and cam gears can i run them @ with no adjustments for awhile till i get more money to get it tuned?
"There's nothing funnier than, a neon owner bashing another neon."
Car Domain
Old 06-12-2008, 10:45 AM   #2 (permalink)
Member Number: 38189
sure just install them straight up, might lope a bit until you get them tuned on the dyno, and fyi both headgaskets are the same, go with the cheaper
rico's-srt is offline   Reply With Quote
Old 06-15-2008, 12:26 AM   #3 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (23)
I had the 2.0 cams, never dyno tuned them, but felt strong set at +2 intake -4exhaust
04 S3 11.90@114 Untuned PCM controlled!
Old 06-15-2008, 08:18 AM   #4 (permalink)
SRTforums Veteran˛
onthedwnlow's Avatar
Member Number: 27125
Trader Rating: (43)
both gaskets are damn near the same.....its not complicated to take apart 2 stock gaskets put the guts from the one in the other the rivot back together.......
i have never heard of a upgraded timing belt for the srt
2.0's are great cams........but after all that why skimp out there and why not get some like 14's?
sorry guys but the car is for sale....all out first gen is in the works
onthedwnlow is offline   Reply With Quote
Old 06-15-2008, 08:39 AM   #5 (permalink)
Member Number: 42667
Why not just buy a factory head gasket. Work just as good as the 5 layer and alot cheaper.
I also have never heard of an upgraded t-belt for an srt-4
05plsrt4 is offline   Reply With Quote
Old 06-15-2008, 08:56 AM   #6 (permalink)
Well after doing a search I just found out there is an upgraded belt.
Old 06-15-2008, 09:05 AM   #7 (permalink)
SRTforums Veteran˛
Trader Rating: (43)
what brand?
Old 06-15-2008, 09:08 AM   #8 (permalink)
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (129)
I assumed he was referring to the Gates timing belt
12.4 @ 126 mph on street tires
Old 06-15-2008, 09:13 AM   #9 (permalink)
Yep.
And just FYI. Gates make the mopar belt.
Old 06-15-2008, 09:14 AM   #10 (permalink)
SRTforums Veteran˛
Trader Rating: (43)
Quote: Originally Posted by 05plsrt4 View Post
Yep.
exactly.....so how is there a diffrence on belts?
Old 06-15-2008, 09:22 AM   #11 (permalink)
Ones blue others black
Usually they use kevlar instead of nylon, but it says nothing about kevlar in that one. I bought one for my RB26 engine and I'm sure it uses kevlar in it.
Old 06-15-2008, 09:22 AM   #12 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (61)
http://www.tkmotorsport.com/ProductD...Code=GATES%2D1
SCT Tuned by Kevin@AGP Turbo
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 06-15-2008, 09:24 AM   #13 (permalink)
nutz's Avatar
Member Number: 41700
its blue and the racing version (says its stronger)
Old 06-15-2008, 09:40 AM   #14 (permalink)
Member Number: 11814
Trader Rating: (91)
Gates has always made high quality belts. Dayco and Goodyear are just cheaper in price and therefore are more common............plus being low cost the quality is not like the Gates.
Old 06-15-2008, 07:15 PM   #15 (permalink)
SRTforums Veteran˛
Trader Rating: (43)
good to know........i wish they were not blue tho......def does not match my underhood colors
Page generated in 0.26434 seconds with 11 queries
