Old 06-02-2008, 11:19 PM   #16 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (17)
Smile
Quote: Originally Posted by DRAST1C. View Post
def. do +1/+2. from the vendors ive talked to its the same price to do the +2exh as it is to do just the +1.
shop around...you can get full out race heads for 900...
Sorry about your banning, but tell me more about this 900$ head? I would like one?
Stg3 toys, ported head & intake, NX 4nozzle, progresser, wide ban, egt, fuel pressure, injen, samco, Mpx3", Maxxfab02,Greddy CC, Boomba's, AIS intercooler, STS, billet SS, .020 8-1 JE's, Eagle 4340 H beam rods, UDP, you name it I've done it Mopar Clutch
Don't be messing with my FJO!!!!
2 180+ Lph pumps feeding the bitch!!!!
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 06-03-2008, 12:22 AM   #17 (permalink)
gq4life's Avatar
Member Number: 10297
Quote: Originally Posted by D_MONEY View Post
or you could go to stock neon dohc specs. the valves fit inside the srt head but you have to grind the seats to fit the +3 exhaust specs. stock neon springs are +1intake and +3exhaust.
i thought someone said +3 wouldnt fit couldnt grind seats out that far..
Old 06-03-2008, 09:29 PM   #18 (permalink)
Member Number: 37178
yeah they fit. i personally havent done it but there are a few on this forum running stock neon valves. when i build my head for my car im going with crane 12's or 2.0's, springs, and dohc valves.
v5 ecut, 3" tbe stock tips, mbc, stg 1, solid mm's, k&n, safc2, agp evm, ptp 75 psi mod, ptp wga, 23/16, wideband, cm wi custom 5 nozzle(100%meth), 100 shot, tbolts, fuel rewire.dual aeroforces, 3"02
ported parts: exh mani., intake mani, turbo, tb
nitrous posts
timing,fpr, octane safc
http://www.srtforums.com/forums/showthread.php?t=362819
big turbo,hobbs switch
http://www.srtforums.com/forums/showthread.php?t=371119
D_MONEY is offline   Reply With Quote
Old 06-03-2008, 09:42 PM   #19 (permalink)
Member Number: 64540
i am almost 100% positive that the stock neon valves are +2 and not +3.
Drasticc is offline   Reply With Quote
Old 06-03-2008, 11:04 PM   #20 (permalink)
gq4life's Avatar
if 2.0 DOHC vavles fit that cheap way to get vavles..
Old 06-04-2008, 09:23 PM   #21 (permalink)
it is. problem is i guess is the material of them get burnt up easily when put thru the abuse and egt's of a srt...
thats what ive HEARD tho, and not sure how that plays out inactual conditions.
+1/+2valves machined and installed is only like 200 tho...so its not bad at all..
Old 06-04-2008, 09:40 PM   #22 (permalink)
Trader Rating: (17)
Smile
that's somewhat true, srt inconel exhaust valve are the most durable on the planet, 2nd only to titanium for heat temperment, but not strenght. I'm in the process of building a head. I'm going with stock valves, just a port and polish. The toughest part for me, is finding someone to do cams, to my spec. I want a .345 lift on the intake, and .285 on the exhaust. I know I won't be able to find what I'm looking for.
Old 06-04-2008, 09:48 PM   #23 (permalink)
why so small on the exh?
stock is .261. 2.0's are .315
why not jus run the 2.0 exh cam?
i lost ZERO spool time w/ my 2.0s after they were tuned...
if not, contact crower...they do custom grinds for customers..
Old 06-04-2008, 10:05 PM   #24 (permalink)
Trader Rating: (17)
Smile
Honestly, I have a set of 2.0L dohc here in my hands. There's too much exhaust & lift, that and the fact the ramp is more steep, and doesn't hold the valve open as long as the .260's of the stock srt.
I'm limited with my stg3 pcm, but I kinda like that. I know that .345 lift on the intake will yield the best of both worlds, with that rpm window in which I'm trying to perfect. The exhaust I only want .285lift, with the same ramp profile on the exhaust side of a stocker. The power should be bumped up in the rpm, but it should yield excellent gain from 3000-6000rpm, and start to fall off, before the 6500 RL. I've thought about doing the 2.0, but I'm thinking about have someone machine down the lobes, to the spec I want? That's if the profile in the cam will allow that, I doubt it thou. I've had both in my hands, to compare them, many times. I'm in the middle of a pickle on this, iwth a back ordered head blues.
Old 06-04-2008, 10:14 PM   #25 (permalink)
send that particular exh cam to crower pimp.
see if they can can shave/regrind and add material where needed to get you the spec on that exh. that you want...
Old 06-04-2008, 10:32 PM   #26 (permalink)
Trader Rating: (17)
that's the plan.........we'll see...... I had the beast running, put a couple of hundred miles on the car. Only to find the stock head, I had cleaned, decked has a micro crack in it somewhere. The car was eating coolant, and doing the same shit I took it apart in the 1st place. Cracked head FTL!!!!
Honestly, I don't want to toot my own horn, but it was nasty. The only good I can take away from this, is now I can do the head, cam, gears now!!!
everthing else I did!!!
Old 06-06-2008, 09:22 PM   #27 (permalink)
Edgehold's Avatar
Member Number: 55411
SO, where can you get these $900 heads at? That would work really nice
Edgehold is offline   Reply With Quote
Old 06-14-2008, 10:42 PM   #28 (permalink)
Member Number: 63506
hey guys sorry to kind hi jack the thread but for all you guys that have 2.0 cams what are they tunes at?...numbers wise on the gears? i have a 50 trim and a shit load of supporting mods plus alky injection and nitrous where do you think i should set them at?
THEMANSRT1 is offline   Reply With Quote
» Search Used Cars
Page generated in 0.28233 seconds with 11 queries
