im looking into different cams and was wondering why everyone uses 2.0l cams. and i know they are very cheap, but what are the specs of the cam and whats the rev limit? thanks in advance.
"The Neon has gone, and with it goes the stupidly fast SRT4." - Automobile Magazine
Liscence is gone till Aug 28 because of a judge abusing his power, to avoid making himself look bad.
Good time to build the car?
the exhaust cam is much larger, which makes more power. Stock turbo you will only get like 10-15 hp when tuned w/ adj. cam gears. It's an 8-10 hr install so maybe not worth it unless you are already in there for something else. If you don't use adj. cam gears you will lose power.
lol 8 to 10 hour install? Maybe for someone with a prosthetic arm....
the hardest part is getting that PITA mount out/off and getting the harmonic balancer off. The rest is pretty straight forward. There are several how-to's on this HELL there is a sticky on 2.0 cams right at the top of the cam section
