Old 06-17-2008, 02:06 PM   #1 (permalink)
Buy/Sell Moderator
uncommonŠ's Avatar
Member Number: 39843
Trader Rating: (131)
Default 2.0 cams owners, post in here.
what's your setup?
what adjustments did you make with the cam gears?
what turbo?
does your setup lope at idle? what's your vac at idle?
did you dyno tune? what gains did you pick up?
etc. etc. ... no discussion thread for strictly 2.0's so I figured I'd make one ... hell, we have a discussion thread for every turbo out there, but none for cams
I have a 60 trim with 2.0's with fidanza cam gears ... just finally got the car up & running with +2 intake & -5 exhaust on the gears ... car lopes a lot more than I expected and vac sits at ~12 ... going to get the car driveable tomorrow & see what I can get out of these cams
11.9 @ 126
uncommonŠ is offline   Reply With Quote
Old 06-17-2008, 02:10 PM   #2 (permalink)
NoisufnoC's Avatar
Member Number: 136
I own a set, but do not own gears. They are not installed.
omgz!! i haz mods!!
Old 06-17-2008, 02:20 PM   #3 (permalink)
Member Number: 64760
Trader Rating: (17)
r u sure your cams are TDC?
at +2, -5 my cams BARELY, and i mean barely had a hint of lope, and my vac was around -18 to -17
my cams were TDC on the dot tho...
91PumpKing. is offline   Reply With Quote
Old 06-17-2008, 02:25 PM   #4 (permalink)
NoisufnoC's Avatar
Member Number: 136
what's your setup like?
Old 06-17-2008, 03:22 PM   #5 (permalink)
Buy/Sell Moderator
uncommonŠ's Avatar
you be the judge...
Old 06-17-2008, 03:23 PM   #6 (permalink)
NoisufnoC's Avatar
Member Number: 136
edit: nevermind.
Old 06-17-2008, 03:23 PM   #7 (permalink)
Buy/Sell Moderator
uncommonŠ's Avatar
you can here the lope in this vid ...
Player detection in Browser...
although the lope is more blatant in person
Old 06-17-2008, 03:25 PM   #8 (permalink)
Buy/Sell Moderator
uncommonŠ's Avatar
Quote: Originally Posted by NoisufnoC View Post
what about the crank?
the motor is already in the car obviously, but the crank arrow is lined up with the arrow on the block ... it's really hard to mess up the timing IMO
the two marks on the cam gears line up & the mark on the block lines up ... if the cam gear were to jump a tooth it would be obvious that the gears weren't lined up ... after doing the timing, I had a couple other people that have done the timing on the srt-4 before & they agreed it looked perfect ... this isn't my first time doing this either - and it looks right on to me
Old 06-17-2008, 03:25 PM   #9 (permalink)
Buy/Sell Moderator
uncommonŠ's Avatar
edit: nevermind.
bastard.
Old 06-17-2008, 03:27 PM   #10 (permalink)
NoisufnoC's Avatar
Member Number: 136
bastard.
i edited after i realized that the crank arrow would have to be lined up with the arrow on the block.
Old 06-17-2008, 03:29 PM   #11 (permalink)
Buy/Sell Moderator
uncommonŠ's Avatar
I know...
I'm curious whether or not other people had as much lope with +2, -5 as I do ...
I know bitts said he had 2.0's and he had +2, -6 (or something like that) and his idled shitty
Old 06-17-2008, 03:36 PM   #12 (permalink)
Member Number: 9221
Trader Rating: (18)
i know there was a dyno done a while ago. Drastic (the guy who is banned every day)ran these for a while try to get in touch with him. I would like to know if they are worth it as well i am ready to sell mine.
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 06-17-2008, 03:39 PM   #13 (permalink)
NoisufnoC's Avatar
Member Number: 136
uncommon, that idle doesn't sound too bad
Old 06-17-2008, 03:40 PM   #14 (permalink)
Buy/Sell Moderator
uncommonŠ's Avatar
I don't want to get anyone banned.... BUT
Old 06-17-2008, 04:08 PM   #15 (permalink)
ibnzmonkey's Avatar
Member Number: 36611
Trader Rating: (13)
Setup: SSTv2, FBM Mammoth manifold, 3" 02, 3" TBE, Fuel mods, BFMIC, Meth, Nitrous, FM Stg 3 WGA 26# spike 22# hold.
Gears: Exhaust -4, Intake +2 (Crane 12's for 2.0L)
Turbo: SSTv2
Idle: Lopes a bit on cold start, dosent lope too much when warm. -17,-18 vac.
Dyno all together 367 whp, 418 tq (Meth). With N2o 438 whp, 512tq. (roughly 60 wet shot)
Race Gas
that hood is as aerodynamic as a sail on a Failboat
ibnzmonkey is offline   Reply With Quote
ť Wheel & Tire Center
