Old 10-31-2009, 07:09 PM   #1 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
Default 2.0 cams lope like a SOB!??
WTF? Are these cams suppose to lope pretty damn hard, or what!
Recently traded a member for some 2.0 cams, and after putting my fully built head on, the cam is just crazy...timing is dead on, and I'm on stock gears....Just wondering.
Old 10-31-2009, 07:27 PM   #2 (permalink)
stage3matt's Avatar
Member Number: 54658
how did you set your timing?
When uncommon and I did his 2.0's we had crazy lope and after checking timing with the timing marks 3 or 4 times we concluded it was perfect.
He bought the DCR cam fixture tool thing and checked it and low and behold it was quite off. Now the car idles completely normally.
2009 1320x threads:
III
stage3matt is offline   Reply With Quote
Old 10-31-2009, 08:36 PM   #3 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
Make Sure They Arnt Set 180* Out Of Phase
Old 10-31-2009, 08:59 PM   #4 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (21)
When I had them they did not lope much at all and that was right after they were installed and at 0/0.
Pensi?
Old 10-31-2009, 09:43 PM   #5 (permalink)
AdvanSRT-4's Avatar
Trader Rating: (57)
They're not 180 out, and my buddy has a tool that I used (kinda like DCR's cam fixture tool)
Unless they're larger than 2.0 cams??
Old 11-01-2009, 12:22 AM   #6 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
slow_spool's loped pretty hard too, and he used the cam fixture tool as well... but then again it might have been how he set the cams..
Pittsburgh Penguins 15-8-0 28 points
Old 11-04-2009, 02:45 PM   #7 (permalink)
Member Number: 76002
Default hai
CarsAddict is offline   Reply With Quote
Old 11-04-2009, 02:47 PM   #8 (permalink)
AdvanSRT-4's Avatar
Trader Rating: (57)
Got it torn apart right now....buddy has the cam at his shop and working on it when he's not busy.
Old 11-04-2009, 09:54 PM   #9 (permalink)
SkullingAxe's Avatar
Member Number: 39463
Trader Rating: (13)
With all the 2.0l cams I've installed, I've never had one set lope real hard straight up. Once I played with cam timing they would, but not at 0,0. Im not sure why some peoples are. Unless they got a set of 2.0l aftermarket cam shafts. Which I doubt. Only thing I can say is to check then double check the timing.
2005 - Flame Red SRT-4
SkullingAxe is online now   Reply With Quote
Old 11-04-2009, 10:14 PM   #10 (permalink)
mikedero08's Avatar
Member Number: 71493
mine sounds pretty mean and the timing is right on.
Full rebuild in progress
mikedero08 is offline   Reply With Quote
Old 11-05-2009, 04:24 PM   #11 (permalink)
stage3matt's Avatar
like I said, we checked timing 2 or three times that night when we got Nate's car together because it was loping pretty good. BOTH of us checked and rechecked and concluded timing was dead balls accurate. Only later when Nate rechecked with the Cam tool did he find out how off it was.
Old 11-06-2009, 11:18 AM   #12 (permalink)
Member Number: 50616
did you just do the exhaust cam or did you do both? iver heard of ppl just changing the exhaust cuz thats the only one that makes the power i guess??
98R/T is offline   Reply With Quote
Old 11-06-2009, 11:45 AM   #13 (permalink)
AdvanSRT-4's Avatar
Trader Rating: (57)
I changed both....But broke the dowel pin off the exhaust cam, but it's being fixed as we speak.
Old 11-06-2009, 12:06 PM   #14 (permalink)
smoothasdee's Avatar
Member Number: 60902
Trader Rating: (62)
i got those babys sit in my garage collecting dust.....have no clue how to install or let alone tune...is there a pretty good hp gain for the amount of work to put them in?
SRT-4:
BMW X5
smoothasdee is online now   Reply With Quote
Old 11-06-2009, 12:37 PM   #15 (permalink)
Ude Lose's Avatar
Member Number: 4562
Trader Rating: (31)
I had the 2.0's in for a year or better. I didnt care for them and put the stockers back in. Now it feels like the car has more top end.
Ude Lose is offline   Reply With Quote
Page generated in 0.15808 seconds with 13 queries
