Try tirerack or other for compatible offsets/rims
If you can't find it on any website, it might be stamped into the casting on the wheel. If you take a wheel off and look at the inside, near the hub, often times the stamping/casting has the wheel size and offset. Or, you could go to several of the wheel-buying sites, type in the car type, and see what they come up with for correct offset and/or compatible offset. Tirerack.com for instance comes up with 18X8 with 19X9.5 with ASA ST-4 type wheels with the following offsets:
Size Selected: 18x8Front
Price: $279 (each)
Estimated Availability: In Stock
Recommended Tire Size: 225/40-18
Wheel Offset: +37mm
Weight: 27.3 lbs.
Size Selected: 19x9.5 Rear
Price: $349 (each)
Recommended Tire Size: 255/35-19
Wheel Offset: +31mm
Weight: 31.7 lbs.
