Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Other SRT/PVO Vehicles > Other SRT/PVO Vehicles > Crossfire SRT-6 Forum
Old 06-23-2008, 09:36 PM   #1 (permalink)
Member Number: 64890
Default Highly recommend the new Hoosier drag radials
Last night, I was supposed to rematch the GTO with the 150shot that beat me by a car length before. So I slapped on the new 275/40/17 Hoosiers. I was spinning on the 19" sumitomo's earlier in the day. With the hoosiers wheel spin is non existant. I couldn't even get the tires to spin when I attempted a burnout. I also launched with the traction control on one time and it never came on and just pulled hard. They are pretty stable as well, but I would hate to get caught in the rain. I went with these over the Mickey Thompson radials because they use plastic radials, making the Hoosiers 8lbs lighter a piece. The GTO backed out so we filmed how the race would have went down.
YouTube - swervin vs brad
12.356@112.29
1.835 60ft
DIY 3" Intake
Inmotion "Needswings" ECU reflash
Johnson CM30
DIY Isolated Intercooler System
ASP 178
srtpowa is offline   Reply With Quote
Old 06-23-2008, 09:52 PM   #2 (permalink)
Member Number: 64702
Mods: Needswings CAI, LET 185mm pulley kit, LET phenolic spacers, LET HE, LET thermostat, LET Tune, Johnson pump, Magnecor wires, NGK +1 iridium plugs, Sprint Booster A2, Auterra A-302.
bluemdsrt6 is offline   Reply With Quote
Old 06-23-2008, 09:53 PM   #3 (permalink)
Old 06-23-2008, 09:54 PM   #4 (permalink)
Nice, can't wait to see what they'll do at the track.
Old 06-23-2008, 09:59 PM   #5 (permalink)
MD SRT6's Avatar
Member Number: 64679
Nice!, I have got to do Something with my rear tires, I have hoosier drag radials on 19's and I have no sidewall and too tall of a tire, I'm looking for a rear wheel/tire combo that is about 25"-25.5" total diam. That still leaves some sidewall for flex.
mods-ported and polished supercharger.intake.heads- cai, 181mm pulley kit,3"stainless exhaust w/cat and resonator delete,hoosier drags,nx pro fogger system with all options,intercooler upgrades,datalogger,widebands,johnson cm30,ignition work,custom tune,piggyback,touchscreen mgmt system.Needswings custom plenums.
MD SRT6 is offline   Reply With Quote
Old 06-23-2008, 10:13 PM   #6 (permalink)
these would be your solution, they are 25.6 OD. I can't say for sure if they would be enough to tame your beast since your making at least 150 more whp. They are about $400 for a set from Summit.
Old 06-25-2008, 02:28 AM   #7 (permalink)
Member Number: 64694
Default hoosiers
Welcome to the "Hoosier Daddy" club. I am getting ready to buy my next set. A whole 2000 miles of track time. Probably 60-80 passes tops. That might be a little high. Anyways the best tire for drag racing. If you don't want it for drag racing only then go with ZR rated drag radials from hoosier. I inquired about them and the rep from CA, said the ZR are not for drag racing. Stay with the R rated ones I use. I'm in a 255/R50-16. The sidewalls are softer and when you lower the pressure they become more like slicks. I'm at 15lbs now with the heat and they are working great. I wouldn't use them as daily drivers though. I won't even do a burnout on the street. I don't want to wear my precious rubber away unless a trophy is on the line. Just my 2 cents. Enjoy them, I am. 2 finals in 3 points races so far. $250 in prize money. It goes to the tire fund.
cruzinquick is offline   Reply With Quote
Old 06-25-2008, 02:31 AM   #8 (permalink)
by the way my source sells my size for $366 a pair plus shipping. Usually $20 a tire. About the norm.
Old 07-20-2008, 08:28 PM   #9 (permalink)
Member Number: 62283
can you post up photos and a link where to purchase the 17" wheels you have?
mrphotoman is offline   Reply With Quote
Old 07-20-2008, 10:37 PM   #10 (permalink)
They don't sell them anymore. I bought them at discounttiredirect.com
BTW I got caught in a heavy downpour a couple weeks ago. I cruised about 40mph the whole way home and they seemed to be alright. Not to bad for a slick with two grooves.
Old 07-23-2008, 05:53 PM   #11 (permalink)
what is the width and backspacing? post the name/model number and i can look it up
Old 07-23-2008, 11:01 PM   #12 (permalink)
They are VOXX Missano 17x9 5x112 40mm(not ideal) offset
Old 07-24-2008, 07:11 AM   #13 (permalink)
Would a 35mm offset be better? I found some 17x9 mercedes wheels that i may pick up that have 35mm offset.
Old 07-25-2008, 06:48 PM   #14 (permalink)
35 is better than 40, but a 22 like the stock rim would be best.
Old 07-30-2008, 05:22 PM   #15 (permalink)
thanks for the info
Page generated in 0.25580 seconds with 13 queries
