Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Other SRT/PVO Vehicles > Other SRT/PVO Vehicles > Crossfire SRT-6 Forum
Old 06-23-2008, 09:21 PM   #1 (permalink)
Member Number: 64702
Default To chop springs or buy eibachs?
Ok here's the deal, I like the way the car handles now but I don't like the wheel gap. Performance being paramount over looks I thinking of keeping the stock springs (they are real stiff) and chop a half inch off the front and one inch off the back. I don't want to go too drastic as I don't want to drive with my eye out for all road imperfections, but I do want to keep the performance I have now while getting rid of some of the wheel gap. Would cutting my springs be a good way to go or would just buying the eibach springs be better? Only thing I have against the eibachs is from what I've seen I think the drop would be enough that I would have to watch out for all road imperfections.
Mods: Needswings CAI, LET 185mm pulley kit, LET phenolic spacers, LET HE, LET thermostat, LET Tune, Johnson pump, Magnecor wires, NGK +1 iridium plugs, Sprint Booster A2, Auterra A-302.
bluemdsrt6 is offline   Reply With Quote
Old 06-23-2008, 09:30 PM   #2 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (167)
neither... heat up the springs until you achieve the height you want
Old 06-23-2008, 09:33 PM   #3 (permalink)
4doorturbo's Avatar
Member Number: 1604
Trader Rating: (15)
Don't cut them or heat them up.....buy the springs
4doorturbo is offline   Reply With Quote
Old 06-23-2008, 09:35 PM   #4 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
I still say heat them up ... they'll ride better than stock when you're done with them
Old 06-24-2008, 08:47 PM   #5 (permalink)
Senior Moderator
Illegal Machine's Avatar
Member Number: 35653
Trader Rating: (19)
Though, if you heat them, and don't tell the dealership, they probably wont void your warranty....
Quote: Originally Posted by sphipps View Post
Obviously you are not detecting the sarcasim in my posts.
Quote: Originally Posted by Ferndogg View Post
Obviously you are not detecting my love for you.
Illegal Machine is offline   Reply With Quote
Old 06-24-2008, 09:29 PM   #6 (permalink)
cokey's Avatar
Member Number: 17219
In for the HA's...
When did I make an account on B20.....?
Idiot...
cokey is offline   Reply With Quote
Old 06-25-2008, 11:45 AM   #7 (permalink)
msheredy's Avatar
Member Number: 51291
This just answered your question about heating the coils—don't.
I have the Eibachs with the thinnest spring pads in both the front and rear and the only thing that I have to watch out for are speed bumps or humps. I have dragged the exhaust a little when I go over the larger ones too carelessly.
I will tell you that I feel the car doesn't handle as well as it did stock though. I think it has to do with the way the sway bars are affected when the car is lowered. Brandon from Code 3 talked to me about this. He makes adjustable end links for the W203 chassis. Since our cars utilize a totally different mount there isn't one being made.
- Matt
2005 SRT-6 Crossfire Coupe
Eibach Pro-Kit
Needswings Cold Air Intake
True Dual exhaust w/X pipe & Magnaflow muffler
2005 C230 Sedan Kompressor
msheredy is offline   Reply With Quote
Old 06-25-2008, 12:38 PM   #8 (permalink)
I did some searching yesturday on the crossfire forum and from what I've read eibachs are not as stiff as the stocks (srt6). They are more for looks and comfort. That's what I suspected from the beginning that's why I was trying to use the stock springs. I guess untill code3 or somebody makes adjustable end links for our car I will just deal with it. Its not really high on my priority list so no biggy.
Old 06-26-2008, 05:24 PM   #9 (permalink)
msheredy's Avatar
Mine is actually quite a bit stiffer than stock. I am using the OEM shocks too.
Old 06-26-2008, 07:52 PM   #10 (permalink)
From the threads that I read they all seemed to say that the spring rate of the eibachs were stiffer than the NA but not as stiff as the srt6. I guess I will have to reasearch the spring rates on each. Since your car is dropped 1+ inch it might seem like there stiffer because of less spring travel and better center of gravity but that doesn't necessarily mean the springs have a stiffer spring rate. Do you have numbers or are you basing this off how the car feels after switching?
Old 06-28-2008, 07:46 PM   #11 (permalink)
MD SRT6's Avatar
Member Number: 64679
I've seen springs both cut and heated a thousand times with no problems, just make sure whoever does the job has experience or they can ruin your springs, And get a four wheel alignment afterwards too.
mods-ported and polished supercharger.intake.heads- cai, 181mm pulley kit,3"stainless exhaust w/cat and resonator delete,hoosier drags,nx pro fogger system with all options,intercooler upgrades,datalogger,widebands,johnson cm30,ignition work,custom tune,piggyback,touchscreen mgmt system.Needswings custom plenums.
MD SRT6 is offline   Reply With Quote
Old 07-01-2008, 12:27 PM   #12 (permalink)
msheredy's Avatar
No numbers. The front springs are a linear rate whereas the rears are progressive, just an FYI.
Old 07-02-2008, 01:12 PM   #13 (permalink)
Satellite's Avatar
Member Number: 11813
Trader Rating: (57)
So "heating up" springs...I've actually never heard of this...where would be more information on this?
Satellite is offline   Reply With Quote
Old 07-02-2008, 01:21 PM   #14 (permalink)
NogaBlitz's Avatar
Member Number: 6194
Trader Rating: (30)
Unless your car is a civic and you've somehow stumbled onto the wrong board....do not chop or heat your springs. The few hundred you spend on replacements will be well worth it.
If it IS a civic, by all means, chop away.
-Stand tall and shake the heavens.
NogaBlitz is offline   Reply With Quote
Old 07-02-2008, 05:20 PM   #15 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
don't do it ...
I was being VERY SARCASTIC when I said to heat the springs ... heating & cutting springs FTL
although, if you really want to... back the car up to a curb that you want your bumper to sit at when it's lowered ... then have a few people sit in the car while you take a torch to the springs ... heat up one side til it the bumper touches the curb and then repeat on the other side
again, don't do it ... you'll regret it
Page generated in 0.19623 seconds with 13 queries
