Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Boomba Racing
Closed Thread
Old 01-16-2005, 03:30 PM   #1 (permalink)
Member Number: 19733
Trader Rating: (36)
Default Transmission mount installation manual 1
TOOLS REQUIRED:
Set of car stands
Hydraulic jack for transmission support
M8 socket wrench
M10 socket wrench
M15 socket wrench
M18 socket wrench
Screwdriver
Pliers
BOOMBA TRANSMISSION MOUNT INSTALLATION MANUAL
When lifting your car always use stands to secure the car.
To make this installation easier, we will remove the air filter box.
Loosen up the air intake tube clamp. Remove the screws securing the solenoid assembly.
Remove the air box cover screws and then remove the cover.
Unplug the air temperature sensor and remove intake short tube.
Remove the screws securing air filter box to the body.
Disconnect the solenoid hose.
Disconnect the vent hose and remove the air box.
If you have any solid engine mounts, disconnect them from the engine. Remove the top engine mount bolt.
Remove the bottom engine mount bolt.
BOOMBA RACING is offline
Closed Thread
Page generated in 0.17653 seconds with 11 queries
