Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Boomba Racing
Closed Thread
Old 01-16-2005, 03:33 PM   #1 (permalink)
Member Number: 19733
Trader Rating: (36)
Default Torque arms installation manual 2
During our installation we will use the set of Boomba high strength bolts.
Bolts are not included with the mount set. They can be purchased separately at our web site www.boombaracing.com.
When using Boomba bolt set we need to recycle one of the stock bolts.
Line up bottom mount with the mounting holes and tighten all bolts.
Install tie bar.
After tightening the bolt the bottom mount engine side bushing should look like on the following picture. It should remain in the center with no excessive bends in any direction.
When looking from the top, the bushing should be square to the mount bracket. We allow maximum +/- 1-degree variation.
Install the top adapter block but don’t tighten bolts yet.
Line up top mount with adaptor block. Install the bolt but don’t tighten it yet. Line up the top mount with the slot on the body side.
Insert the body side bolt. Tighten all top mount bolts.
Install the splashguard.
Install and secure the right (passenger side) wheel.
BOOMBA RACING is offline
Closed Thread
Page generated in 0.16155 seconds with 11 queries
