Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Boomba Racing
Closed Thread
Old 05-21-2006, 10:30 PM   #1 (permalink)
Member Number: 19733
Trader Rating: (36)
Default Throttle body installation manual 1
TOOLS REQUIRED:
M8 socket wrench
M10 socket wrench
M13 socket wrench
M6 Allen Wrench
Flat Screwdriver
T25 Torx Wrench
BOOMBA THROTLE BODY INSTALLATION MANUAL
To make this installation easier, we will remove the air filter box.
Loosen up the air intake tube clamp. Remove the screws securing the solenoid assembly.
Remove the air box cover screws and then remove the cover.
Unplug the air temperature sensor and remove intake short tube.
Remove the screws securing air filter box to the body.
Disconnect the solenoid hose.
Disconnect the vent hose and remove the air box.
Disconnect electrical plugs and vacuum hose.
Remove screws holding throttle cable bracket.
Remove throttle cable.
Loosen up hose clamp and remove air supply hose.
Remove throttle body screws. Remove throttle body and adaptor.
BOOMBA RACING is offline
Closed Thread
Page generated in 0.17023 seconds with 11 queries
