03-25-2007, 07:15 PM
#1 (permalink )
Member Number: 2057
Installed intake gasket
So...did anyone else end up having to modify the bottom bracket?
-rejected print ad slogan for the 2003 SRT-4:
"hi, motherf***er."
Mods:
Yes. I've got some, thanks!
03-25-2007, 07:19 PM
#2 (permalink )
Member Number: 7795
No Man, I just put mine on last weekend and it fit perfect! I didn't have to change a thing. So what did you have to do, or what do you mean modify?
03-25-2007, 07:39 PM
#3 (permalink )
Member Number: 2057
I ended up having to open up the top hole of the bracket just a bit...the extra thickness of the bracket made it so that the top bolt just barely wouldn't line up properly.
03-25-2007, 07:45 PM
#4 (permalink )
Member Number: 2385
Same here, no modification necessary. Was it just a little misaligned or was it alot?
03-25-2007, 07:47 PM
#5 (permalink )
Member Number: 2057
Just a little. Maybe a millimeter, if that. Just enough that the bolt wouldn't go in.
03-25-2007, 07:50 PM
#6 (permalink )
Member Number: 13593
I just loosened the bracket and with just a little bit of angling, it fit right in with no problem. Then after I got the gasket in, it bolted right back. I installed it yesterday arvo.
There's more than meets the eye.
03-25-2007, 07:58 PM
#7 (permalink )
Member Number: 2057
Ok...just me then. I think the reason was that I tightened and torqued the bolts to spec before putting the bracket on. Just enough to misalign it...
03-26-2007, 09:58 AM
#8 (permalink )
Member Number: 25197
That bracket should have 2 bolts holding it on, one on either side. I just loosened both and it was free to move to wherever I needed it.
03-26-2007, 10:36 AM
#9 (permalink )
Member Number: 2057
It did, I did, and it wasn't...
Linear Mode
» Site Navigation
> Other Vehicles
» Network Links
