Like the title says how about a group buy on your tb.
DODGE NEON SRT4 - Boomba Throttle Body - $345.00
Boomba throttle body comes as a kit including adaptor plate, 55 MM hose adaptor (for those that want to use it immediately with stock intake pipes), 70 MM hose adaptor and all mounting hardware. Throttle bodies are CNC machined of billet aluminum. Parts are available in natural aluminum and blue anodized finishes. Increasing diameter to 70 MM gives almost 65% increase in throttle cross section area. Replacing stock throttle body with our new 70 MM (even with stock pipes and turbo) will give you a few additional HPs and greatly improve engine response. Replacing stock throttle body with our 70 MM throttle body and replacing intake piping with larger diameter (70 MM) gives limitless possibilities of increasing engine power. All parts are manufactured to our legendary high quality standards and backed up by our warranty. As additional service we offer modifying Intake manifolds to allow better air flow with our large diameter throttle body.
Maybe even a combo group buy tb,Intake manifold gasket
DODGE NEON SRT4 - Intake Gasket - $50.00
Boomba Racing has developed a special high temperature insulating gasket which replaces stock intake gasket. Turbocharged cars use aluminum intercoolers to cool the air compressed by the turbocharger. Colder air has lesser volume, which means that more air (and oxygen) can be fed to the cylinders. Intake manifold is also made of aluminum. It is mounted to the head and absorbs heat generated during combustion. Forcing air thru hot intake manifold reverses benefits of intercooler. Insulating gasket separates head and manifold significantly reducing heat transfer. During average driving conditions temperature drop up to 50 F can be achieved. That transfers into 5-10% power increase. All necessary hardware is included.
A853 CREW (ONLY UNO)Project TRAIN DONE!11/13/09 F&FPorted E/M Agp RACE Bfmic Agp uhp+hks
Ported Stock turbo,Stock Head, Stock cams
329.69Hp, 395.77Tq STD 297Hp@6K
320.87Hp, 385.18Tq SAE E-85 CORN FED BABY!
