Quote: Originally Posted by Bionic
I had some problems with the piston sticking on mine, esp when the weather got colder.
I opened mine up and sprayed the piston lightly with some WD40, then wiped it off so there was only a thin film left on the outside edges of the piston.
Never had a problem with it since.
Thanks for the help man. Thats exactly what the problem was. The piston was sticking and not closing all the way up. I took it off this afternoon, took it apart and then put a thin film of wd-40 on the piston, reassembled, made a new gasket and put it back on. It works perfectly now.
I hope I don't have to do this very often because that third bolt is a dirty whore and although I've figured out a good way to get at it, it still sucks to deal with!
