Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Boomba Racing
Old 07-27-2009, 12:45 PM   #1 (permalink)
BDCarrillo's Avatar
Member Number: 59014
Trader Rating: (13)
Default Fuel Rail Question
I'm planning on running a -6 feed and return line. Obviously i'll put -8 o-ring to -6 adapters in the ends.
Instead of putting the fuel inlet in the side, can I take out the factory adapter and go straight into that hole? I'm assuming that one is also -8.
Pony - 1989 5.0 LX Convertible - 200hp/266tq old 302
Ol' Girl - 1971 Mach 1
Skittle - 2005 SRT4 - 229hp/259tq stock 281/327 stg2 12.6@114mph
BDCarrillo is offline   Reply With Quote
Old 07-27-2009, 01:47 PM   #2 (permalink)
Member Number: 52801
i have -8 lines. my fuel line goes into the side input.
AGP 3147, BOOMBA THROTTLE BODY, 3IN TBE, DW 750'S, WALBRO 255, RETURN LINE, MSD DIS 2 AND WIRES, ED HARD PIPES, ED CHARGE PIPE, HKS BOV, BFG DR'S ON ROTA'S, MOPAR STS, AEM WIDE BAND, AEM TRU-BOOST, AEROFORCE SCANGUAGE, SNOW PERFORMANCE STAGE 2, CAI
EDOGSRT is offline   Reply With Quote
Old 07-27-2009, 02:48 PM   #3 (permalink)
BDCarrillo's Avatar
Trader Rating: (13)
Did you have clearance issues with the T-Stat housing?
Old 07-27-2009, 07:18 PM   #4 (permalink)
no issues.
Old 07-27-2009, 10:30 PM   #5 (permalink)
BDCarrillo's Avatar
Trader Rating: (13)
no issues.
Roger, thanks!
Old 07-28-2009, 05:46 PM   #6 (permalink)
gump1114's Avatar
Member Number: 28766
Trader Rating: (12)
can you show a picture of exactly how you did it. i've hear of clearance issues with doing it this way.
Broken-ISH.
gump1114 is offline   Reply With Quote
Old 07-28-2009, 05:57 PM   #7 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (122)
I think the two ends of the rails are -8AN the location up top is -6AN (I think both are o-ringed as well)
I'm using this fuel rail and I have the inlet on the end. I used an Earls ANO-Tuff fitting and a thermost spacer from Rage-Tek.
Heres the fitting I used on the inlet
Holley Performance Products 90° -6 AN Male to 9/16"-24 Swivel*AT949094ERL
Old 07-28-2009, 07:30 PM   #8 (permalink)
I used
JEGS AN to AN Radiused Pump Fittings
JEGS AN Push-Loc Hose End Fittings - Black 90deg.
i didn't need any spacer for the tstat housing with these fittings
Old 07-30-2009, 11:20 PM   #9 (permalink)
Member Number: 28737
Trader Rating: (82)
Stock location is -6
Passenger side top is -6.
Passenger side bottom is -8
Driver's side is -8
Token Boomba Racing SRT-4
Maddog STS Info
taco is online now   Reply With Quote
Old 07-31-2009, 08:02 AM   #10 (permalink)
BDCarrillo's Avatar
Trader Rating: (13)
Driver's side is -8
Thanks for the info everyone! The rail is in hand right now. It'd be nice for boomba to put the sizes for the stock location and second one on the passenger side.
Page generated in 0.16745 seconds with 13 queries
