Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Boomba Racing
Old 02-15-2009, 07:18 PM   #1 (permalink)
CIVICEATER's Avatar
Member Number: 16703
Trader Rating: (12)
Default Fuel Rail?
I'm interested in your fuel rail, but need to know if you can use the -8 AN port closest to the thermostat as a feed or can they only be used as returns. I'm going with a -8 AN feed and -6 AN return on my new fuel system and theres no point to feed that much fuel through a bottleneck (-6 AN fitting). Thanks.
2003 Solar Yellow SRT-4
FFP 47LB Stage 3
Coolingmist Trunkmount Kit with Varicool Controller
MPx 3" Exhaust
AGP Intercooler
AGP CAI
Diablosport Tuner
11.87 - 118.94mph
^^22PSI on HOM (getting kicked out) and no tune
CIVICEATER is offline   Reply With Quote
Old 02-17-2009, 08:25 AM   #2 (permalink)
BOOMBA RACING's Avatar
Member Number: 19733
Trader Rating: (43)
We suggest using AN-8 port opposite to the thermostat as a feed.
BOOMBA RACING is offline   Reply With Quote
Old 02-17-2009, 11:03 AM   #3 (permalink)
CIVICEATER's Avatar
Trader Rating: (12)
Why do you suggest using the port opposite to the thermostat as a feed? I wanted to use that for my return as my reg would fit perfect there.
Old 02-17-2009, 09:17 PM   #4 (permalink)
Member Number: 28737
Trader Rating: (82)
You can use a -8 as the feed near the thermostat but it will be VERY tight. I'd recommend a thermostat housing spacer that you can get at rage-tek if that's your plan. If you want to try to squeeze one in there just be aware of the lack of room and order fittings accordingly
Token Boomba Racing SRT-4
Maddog STS Info
taco is offline   Reply With Quote
Old 02-18-2009, 07:28 AM   #5 (permalink)
CIVICEATER's Avatar
Trader Rating: (12)
Yea I know it's real tight there with an -8an line and was planning on running the rage thermostat spacer. I just want to make sure that it will work on that side of the rail.
Old 02-18-2009, 02:26 PM   #6 (permalink)
GreddyHovs's Avatar
Member Number: 62333
I received my boomba fuel rail 2 days ago and am very pleased with it. Can you confirm that the fitting farthest to the right on the rail is a -8an fitting ? I also have JMB's fuel return line kit. I believe the fitting they supplied me is a -8an to -6an to connect to the fuel line that connects to the regulator. Feel free to correct me.
-- GT3076R, 750cc Injectors, Walbro Fuel Pump, Boomba Fuel Rail, JMB Fuel Return Line, SCT tune, 3" Catless Mpx Turbo Back Exhaust, Mpx FMIC, Clutch Masters FX400, Megan Racing Coilovers, AGP Motor Mounts, HKS SSQV, AEM UEGO, Phantom II Gauges, Interceptor Scan Gauge
GreddyHovs is offline   Reply With Quote
Old 02-18-2009, 02:45 PM   #7 (permalink)
Trader Rating: (43)
On our fuel rail all ports with bigger plugs are AN-8 and all ports with smaller plugs are AN-6.
Old 02-18-2009, 02:55 PM   #8 (permalink)
GreddyHovs's Avatar
Thank you. I originally asked Justin at JMB to supply the correct fitting so I can mount the FPR to the end of the fuel rail. The fitting he supplied is a -8/-6an. Mount's right up to my aeromotive regulator. Do you have any negative comment's on mounting the regulator to the fail. I've read that there can be problem's with vibration's and clearence with the hood.
Old 02-18-2009, 11:40 PM   #9 (permalink)
Trader Rating: (82)
Yes it will work fine like that
I run my regulator directly off the rail with no problems
Old 02-18-2009, 11:42 PM   #10 (permalink)
GreddyHovs's Avatar
^^^^ What fuel rail are you running ? If people are running the stock fuel rail with the FPR attached and ot having problems, I should be more than fine with the boomba fuel rail.
Old 02-19-2009, 01:23 AM   #11 (permalink)
Trader Rating: (82)
Boomba rail with fuel lab regulator
Old 02-19-2009, 07:34 AM   #12 (permalink)
blksrt404's Avatar
Member Number: 4798
Trader Rating: (32)
Thanks man you just answered my question I was about to PM you...
Btw...I have your fuel rail, IM gasket and TB and luv'um all great products
2009 Mid-West Nats Winner - OPEN Class
Best for 2009 so far 10.784 @ 129.26
Fastest SRT4 in Canada for 2007 @ 128.77
Quickest SRT4 in Canada for 2007 @ 11.286
First to run in the 10's in Canada
DCR Built and Loved
blksrt404 is offline   Reply With Quote
Page generated in 0.19718 seconds with 13 queries
