Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Boomba Racing
Closed Thread
Old 01-16-2005, 03:34 PM   #1 (permalink)
Member Number: 19733
Trader Rating: (36)
Default BOV installation manual
TOOLS REQUIRED:
M10 socket wrench
M12 socket wrench
Screwdriver
Pliers
BOOMBA BOV INSTALLATION MANUAL
Loosen up the battery terminal bolts.
Remove the battery terminals and unplug battery temperature sensor.
Loosen the battery clamp and remove the battery.
Disconnect vacuum hose from the BOV and remove the ground wire.
Remove BOV bolts and remove BOV.
Assemble Boomba BOV and gasket.
Align the opening in the turbo housing with the opening in BOV, and then bolt on BOV.
Connect the vacuum line and ground wire.
Install the battery, connect the battery temperature sensor and battery terminals.
BOOMBA RACING is offline
Closed Thread
Page generated in 0.27072 seconds with 11 queries
