Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Boomba Racing
Old 08-17-2009, 11:41 AM   #1 (permalink)
14adamneonsrt-4's Avatar
Member Number: 74540
Default Boomba Throttle Body Question
I just installed a new Boomba Throttle Body and after install my SRT idles high and I can't figure out what the issue is. When I depress the clutch the engine revs to about 2500 and drops to 1500 and so on. When the tranny is put into neutral the rpms stay consistently at 2000. I'm thinking I have some kind of air leak in my system. Any ideas?
14adamneonsrt-4 is offline   Reply With Quote
Old 08-17-2009, 11:44 AM   #2 (permalink)
I've also read many of the threads that are similar to my issue. The only issue I have with those is my throttle body was a direct swap out, meaning the only thing changed on either end was the throttle body. Intake mani and tubing to the tb are stock.
Old 08-17-2009, 11:52 AM   #3 (permalink)
Senior Moderator
kritical's Avatar
Member Number: 49262
Trader Rating: (138)
since you moved around the wires i would check the tps and iac wiring itself. wiggle the wires around while the car is on and see if anything changes. If it does you need to replace the wiring.
stock
kritical is offline   Reply With Quote
Old 08-17-2009, 12:29 PM   #4 (permalink)
Thanks, I'll try that soon as I get home from work this afternoon.
Old 08-17-2009, 01:45 PM   #5 (permalink)
Member Number: 52801
did you put in a new o-ring for the tps sensor?
AGP 3147, BOOMBA THROTTLE BODY, 3IN TBE, DW 750'S, WALBRO 255, RETURN LINE, MSD DIS 2 AND WIRES, ED HARD PIPES, ED CHARGE PIPE, HKS BOV, BFG DR'S ON ROTA'S, MOPAR STS, AEM WIDE BAND, AEM TRU-BOOST, AEROFORCE SCANGUAGE, SNOW PERFORMANCE STAGE 2, CAI
EDOGSRT is offline   Reply With Quote
Old 08-17-2009, 01:47 PM   #6 (permalink)
No, the tb kit didn't come with one and I didn't have one on hand. Do I need to order one? And would I just get that from a dealership?
Old 08-17-2009, 03:14 PM   #7 (permalink)
thats your problem. you need an o-ring on that sensor. you have an air leak. you can get an o-ring at autozone. i had to match mine up. the dealer only sells the o-ring with the sensor.
Old 08-17-2009, 03:23 PM   #8 (permalink)
This is a stupid question but the TPS sensor is the one on top side of the tb or the bottom?
Old 08-17-2009, 03:29 PM   #9 (permalink)
the sensor on the top is the idle air control solenoid. the sensor on the side is the throttle position sensor.
Old 08-18-2009, 12:17 PM   #10 (permalink)
Ok, I went to NAPA yesterday and ordered the o rings and the service guy told me that there are 3 o rings and one gasket on the TPS. Is this correct? Should I just change them all out?
Old 08-18-2009, 12:20 PM   #11 (permalink)
Senior Moderator
kritical's Avatar
i would replace them all since it is inexpensive..
Old 08-20-2009, 02:55 PM   #12 (permalink)
Ok replaced all o-rings (two on idle air control and one on TPS) seemed to idle alright. Bad weather here last night though so I'll have to wait till after work today to see how she runs.
Old 08-20-2009, 06:00 PM   #13 (permalink)
Ok just got done driving the car and it drove the same. So, while messing with it I removed the idle air control plug and it drove fine. All the problems went away. Obviously this is the part that is broken but what makes it run fine without it and should I replace it?
Old 08-25-2009, 08:53 PM   #14 (permalink)
Bump for any help
Old 09-02-2009, 12:25 AM   #15 (permalink)
sauce07's Avatar
Member Number: 52773
im having the same problem right now!!! what o rings did u buy so i can get them?
BB HTA 60 ON METH LIKE A CRACKHEAD!!!!
sauce07 is offline   Reply With Quote
Page generated in 0.19132 seconds with 13 queries
