Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Boomba Racing
Old 11-16-2008, 01:13 PM   #1 (permalink)
mightyxwhitey53's Avatar
Member Number: 30679
Default Boomba TB question
hey ive got the Realtune/DCR Intake Mani/Boomba TB and I love it but sometimes the throttle linkage comes halfway off the TB....anyway to remedy this?
Texas' first DCR SRT TT 11.30@126.02
Forever Tuned by Mark Riley
531hp 450tq 5 spd
420hp 400tq 3 spd auto
Quote: Originally Posted by stowaway
Dear mightyxwhitey53,
You have received an infraction at SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum.
Reason: Bashing a 'tard
mightyxwhitey53 is offline   Reply With Quote
Old 11-17-2008, 05:39 PM   #2 (permalink)
BOOMBA RACING's Avatar
Member Number: 19733
Trader Rating: (43)
Make sure that cable is secured properly to the throttle body. Lubricate cable. Most likely cable is jamming somewhere.
BOOMBA RACING is offline   Reply With Quote
Old 11-17-2008, 06:39 PM   #3 (permalink)
sorry i meant the cable comes off the throttle linkage...what would i use to lubricate? silicone lube?
Old 11-18-2008, 04:57 PM   #4 (permalink)
Trader Rating: (43)
WD 40
Old 11-18-2008, 05:17 PM   #5 (permalink)
WD 40
rgr tks
Old 01-17-2009, 04:28 PM   #6 (permalink)
2K4SRT_4's Avatar
Member Number: 13287
Trader Rating: (29)
i have the same manifold and my rpms are shooting up when the car is at a stand still after i give it a little gas. if i manually rev it from the tb itself. it seems to be really slow to bring the rpms down. any idea?
2K4SRT_4 is offline   Reply With Quote
Old 01-17-2009, 10:56 PM   #7 (permalink)
2K4SRT_4's Avatar
Trader Rating: (29)
nevermind i figured out the problem.
Old 01-20-2009, 08:34 AM   #8 (permalink)
2K4SRT_4's Avatar
Trader Rating: (29)
Ok somewhat the same problem. I am having rpm hanging while driving. I think I might have a leak at my bov. So I am going to fix that. But could there be anything else that would cause the hanging from the tb?
Old 01-20-2009, 04:13 PM   #9 (permalink)
Trader Rating: (43)
This is usually the throttle cable problem. Just to make sure you can remove the cable and pull on the throttle lever to see if it is catching something during the travel.
Old 01-20-2009, 04:49 PM   #10 (permalink)
2K4SRT_4's Avatar
Trader Rating: (29)
well i did that and it was not the cable catching. it was the fly hitting the inner walls. I can see where the fly rubbed a little path inside the wall. I spray some liquid wrench in there and it shut pretty good. but over time the air is just drying it up.
Old 01-21-2009, 09:41 AM   #11 (permalink)
Trader Rating: (43)
You have to readjust the throttle plate limit screw so the plate doesn't hit the wall.
Old 01-21-2009, 09:44 AM   #12 (permalink)
2K4SRT_4's Avatar
Trader Rating: (29)
ok i can understand that. but its hitting the wall at the pivot point. don't thing you can adjust that out.
Old 01-21-2009, 09:48 AM   #13 (permalink)
2K4SRT_4's Avatar
Trader Rating: (29)
ok it looks like i fixed the problem last night.
Old 01-24-2009, 10:21 PM   #14 (permalink)
Hemicross's Avatar
Member Number: 60251
what is the TPS voltage reading spec supposed to be?
Hemicross is offline   Reply With Quote
Page generated in 0.17246 seconds with 13 queries
