Old 08-10-2009, 11:51 PM   #1 (permalink)
Big D's Blue 04's Avatar
Member Number: 32123
Trader Rating: (31)
Default Zex WOT switch with N2MB WOT Box??
Haven't seen anything addressing this yet, as anyone run a Zex wot controller and a wot box? I want to but I'm thinking the only way to make it work is as soon as the car leaves the line in between shifting to 2nd flip the arm switch on so that Zex box will kick on, because it would not be good to it on from the get go (spraying during 2 step = bad lol)
So anyone have any thoughts on this, similar setup ideas, or other routs I could take.
Also I'm not sure how the Zex box would respond to being turned on while already at WOT, not sure if that would cause an issue with it or not, again if anyone has done any testing or is already doing this let me know.
Thanks,
Big D
The Peoples Mechanic!!!!
813-892-7215 help with installs, mods, dsp tuning or sound SRT-4 advice, Big D for the people.
Big D's Blue 04 is offline   Reply With Quote
Old 08-11-2009, 06:36 AM   #2 (permalink)
toyoguru's Avatar
Member Number: 6185
thats how im gonna do my wot switch, but mines a direct port setup so im gonna hit it probally in 2nd
Socialism - Screwing the working man since 1789
stage3
491whp & 580wtq
toyoguru is offline   Reply With Quote
Old 08-11-2009, 08:12 AM   #3 (permalink)
Trader Rating: (31)
I'm running direct port too, NX kit with a 100 shot, so you think 2nd is the best place to start spaying?
Old 08-11-2009, 07:49 PM   #4 (permalink)
Rhunter's Avatar
Member Number: 36794
The Zex tps is activated by wide open throttle voltage right? the 2-step is set via RPM right? I would think they can both co-exist right?
I know phrozen and Jay are working on a cable to cut off the nitrous during WOT shifts.
lets bump this up for some input from N2MB. I have a vested interest in this topic as well.
BUMP!!!
Rhunter is online now   Reply With Quote
Old 08-12-2009, 07:07 PM   #5 (permalink)
toyoguru's Avatar
Member Number: 6185
As far as WOT shifting, a simple switch off of the clutch would cut the nitrous off between shifts..
A cheap way to spray from second gear on automatically without flipping a switch after the 1-2 shift is another story..
Old 08-12-2009, 08:41 PM   #6 (permalink)
Rhunter's Avatar
The Cable or module that N2MB is working on is an add on for the wot box and you would still have the wotbox/2-step functions with the added bonus of cutting off the iginition and solnoids during a wot shift.
From my understanding it's TPS activated so I guess you could launch off of the 2-step, then go full throttle activating the nitrous, the wot box with nitrous module would take care of the rest of the run.
I'm hoping phrozen will chime in. Lots of folks are waiting for the nitrous module.
Old 08-12-2009, 08:53 PM   #7 (permalink)
NJ DSM's Avatar
Member Number: 46989
Trader Rating: (34)
Its all traction controlled...i have gone 1-2-3-4 but never made a clean pass, but 2-3-4 i did 11.8. There is definately faster times to be had spraying all 4 gears off the line
I have my window set from 3-5900, and use the wot box shifting at 6k when i spray. my nitrous and wot box coexist well together
351/390 on Mustang DynoSTOCK TURBO
RUN YOUR CAR NOT YOUR MOUTH
NJ DSM is online now   Reply With Quote
Old 08-12-2009, 09:36 PM   #8 (permalink)
Rhunter's Avatar
So you are wot shifting outside of your nitrous window?
Old 08-12-2009, 09:49 PM   #9 (permalink)
Rhunter's Avatar
I spun 24" slicks spraying 1st, but the track really sucked. there was rubber build up and they just kept spraying vht on top of it.
Ran 8.2 @ 91.7mph spraying 2nd & 3rd
I'm hoping to get to the track friday night. This will be a better prepped track (I hope) and I'll try a lil lower tire pressure to see if i can get traction while spraying of the line.
Old 08-13-2009, 11:49 AM   #10 (permalink)
TurboJay's Avatar
Member Number: 56316
Im spraying out of the hole now no 2 step. However im not to sure about the zex wot switch. In my setup im gonna run a 2 step and set my dynotune box to skip first gear and spray in 2nd that way I can have both unless I change my mind. However if you want to spray out of the hole on the 2 step you still should be able to I would think because even though the rpms are in the spraying range and your foot is all the way down on the gas the clutch is still pressed in. I would think you would be able to set it somehow so when the clutch is in it wont spray but I could be all wrong just thought I heard thats an option for both
05 Stone White SRT 4
Quote: Originally Posted by HAVOKSRT4
I say move out of the rural area and into the city. Just becareful of crackheads and basers because they freeze like deer do.
Quote: Originally Posted by Slow_spool View Post
no offense but the port work looks like Ray Charles did it.
TurboJay is offline   Reply With Quote
Old 08-13-2009, 02:45 PM   #11 (permalink)
Trader Rating: (31)
I wonder... the main power wires coming form the wot box that you cut and splice into the your ignition wires, it cuts power to those during wot shifts, we'll there 12v power wires to your injectors and coils, so what if you ran the Zex controllers power wire through that after the wot box then it would also be cutting power to the zex controller during wot shifts, as long long as the zex controller wouldn't be to much extra load on that wire causing ignition problems that would work for shifting. 2 stepping though you would still have to flip a switch. So set the switch up close to the shifter and easy to reach without moving your body, launch, flip, 2nd... and so on.
Old 08-13-2009, 04:03 PM   #12 (permalink)
Rhunter's Avatar
Or wait until N2MB releases there nitrous module that plugs into the wot box to allow full fuctionality of 2-step/wot box with nitrous.
That's what I'm gonna do. I'm trying to limit the number of boxs switches and diods I'm adding to the car.
Old 08-13-2009, 11:15 PM   #13 (permalink)
Trader Rating: (31)
I agree, the ghetto setup is not for me car! I will be waiting for N2MB
Old 08-14-2009, 01:20 AM   #14 (permalink)
milkman102299's Avatar
Member Number: 25193
Trader Rating: (15)
here is what I did. on STG 2 shifting at 6400 I drop to about 4800 rps. Set my 2 step to 4400 and My nitrous to kick on at 4800(msd window switch) and off at 6200. Now I can WOT shift and use my 2 off the line with both the WOT Box and dynotune tps switch.
Wiseco 8.0-1 pistons over-eagle H beam rods
agp standard 50 trim
Greddy Profec B. SAFC II
PTP charge pipe
PTP 750cc-exhaust depot cold side pipe w/hks ssq
3inch intake-accel coil-stg 2 CPU
side exit
Boomba Fuel Rail/AGP return line
Walbro 255-Dynotune 105 shot.
DCR powershift 2-balance shafts removed
coolingmist meth kit. BC3 cams.
N2MB WOT BOX (BEST MOD SO FAR)
milkman102299 is offline   Reply With Quote
Old 08-14-2009, 06:04 PM   #15 (permalink)
NJ DSM's Avatar
Trader Rating: (34)
well my car is an 05 with no staged computer, so i shift at fatory redline.
window switch set from 3k-5900, redline being 6 i shift @ 6.
over 7 bottles last spring at the track and new jersey highways worth
Page generated in 0.20530 seconds with 13 queries
