Old 03-24-2008, 03:06 PM   #1 (permalink)
Member Number: 60369
Default Zex Kit Nozzle Question
Zex install instructions show tapping the intake manifold itself (with supplied tap) and installing the nozzle there. Problem is i worry about it staying just "threaded" into the plastic of the cold side pipe. Any suggestions or has anyone had issues with the setup from ZEX?
Old 03-24-2008, 03:09 PM   #2 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (24)
You should install it BEFORE the throttle body in your cold side pipe...somewhere around 6" prior to the TB
Old 03-24-2008, 03:14 PM   #3 (permalink)
Yea realized what i orginally posted, now just wondering if the thread in style (versus the nut style on NOS setups) is going to stay in there.
Old 03-24-2008, 04:13 PM   #4 (permalink)
Member Number: 11814
Trader Rating: (91)
Loctite OR dill and mount in the spacer. But it seems as if almost everyone is not having an issue with mounting in cold side pipe. For those with the stock pipe I think most are drilling and mounting into the plastic section and using the locking nut. If you're using or want to, I'm sure a hard pipe setup can be ordered from hard pipe maker with a welded on bung for the fogger to the pipe in the location you chose for a few more $$.
turbojack is online now   Reply With Quote
Page generated in 0.18855 seconds with 11 queries
