Old 04-13-2009, 05:52 PM   #1 (permalink)
Member Number: 56991
Default WOT A/F with No2 Help
So I had kevin from AGP make me a tune up for the Zex 50shot and I took it out for the first time and at WOT my A/F where set AT 10 the entire time. Right now my jets are set at Fuel 17, NO2 32. Is it the Tune that is pulling to much fuel or is it that my fuel jet is to big??
99.9% Stock!
RaiedZ is offline   Reply With Quote
Old 04-13-2009, 07:42 PM   #2 (permalink)
Rhunter's Avatar
Member Number: 36794
What are your AFR's when you are not spraying? If they are in the 10's when you spray, I would try going down 1 fuel pill sized.
You might want to monitor knock tho.
Rhunter is online now   Reply With Quote
Old 04-14-2009, 11:50 PM   #3 (permalink)
A/Fs are in High Tens without spraying. I have a scan gauge with the spray haven't seen any knock yet. So I need to buy a small fuel jet.
Old 04-15-2009, 12:30 AM   #4 (permalink)
Member Number: 37178
yes and a better tune off nitrous. should be in the 11's without nitrous. i target tune for about 11.8:1 off nitrous then tune with the nitrous pill to get close to your original tune.
v5 ecut, 3" tbe stock tips, mbc, stg 1, solid mm's, k&n, safc2, agp evm, ptp 75 psi mod, ptp wga, 23/16, wideband, cm wi custom 5 nozzle(100%meth), 100 shot, tbolts, fuel rewire.dual aeroforces, 3"02
ported parts: exh mani., intake mani, turbo, tb
nitrous posts
timing,fpr, octane safc
http://www.srtforums.com/forums/showthread.php?t=362819
big turbo,hobbs switch
http://www.srtforums.com/forums/showthread.php?t=371119
D_MONEY is offline   Reply With Quote
Page generated in 0.13479 seconds with 13 queries
