Spark Plug Information - Dodge SRT Forum
post #1 of 22 (permalink) Old 09-21-2010, 04:21 PM Thread Starter
Quoted: 0 Post(s)
Here is some good information compiled by myself and Brandon from NGK. Now these are all NGK plugs. I use NGK for two reasons:
1) They make exceptional product and are OEM manufacturers on many platforms.
2) Their tech support ( I always deal with Brandon.) is simply amazing. They are fairly fast for a company of their size and are very knowledgeable. Polite as well.
Stock or near stock:
NGK#4306
This is a projected tip #5 heat range plug. This is the plug I would recommend for stock replacement as well as cars with minor mods such as intake/exhaust. If you have increased boost or are ready for nitrous see below.
Higher than stock boost OR nitrous:
NGK#2315
This is the same projected tip plug as above, but in a #6 heat range. If you are going to hit the car with nitrous less than a 75 shot OR increase boost, then you need to go to this heat range plug.
Higher than stock boost AND nitrous:
NGK#5107
Again same plug, two heat ranges colder than stock, resulting in a #7 heat range. This is plug I recommend for cars with high psi and nitrous. Now if you have stock psi but a fairly large nitrous shot, I would also recommend going to this plug. I think at 75 shot its optional but recommend, after that I would call it mandatory.
Little general plug tech
Plug styles
There are projected and non-projected type plugs. It means just what it says, the electrode of the plug either protrudes from the end of the threads, or it does not. Generally, non-projected tip are preferred in nitrous applications. However, These are not available for the srt-4. While I would prefer them, its fine to run on the plugs at hand as long as the tune is safe.
Heat ranges:
In performance applications it is at times needed to go to a "colder" spark plug. This is in reference to the amount of heat a spark plug will release into the cylinder head. It is in no way a reference to the amount of spark or the temperature of the spark. This is a common misconception tho.
I know some read a previous post I made on spark plug and choosing them for you vehicle. This is simply a cleaner more organized format. The information is the same.
NitrousExpress is offline
post #2 of 22 (permalink) Old 09-21-2010, 08:00 PM
New Member
Turboboxboy's Avatar
Quoted: 0 Post(s)
This should be stickied...
Turboboxboy is offline
post #3 of 22 (permalink) Old 09-22-2010, 05:45 PM
prevrexowner's Avatar
Quoted: 0 Post(s)
Good info. . . .
prevrexowner is offline
post #4 of 22 (permalink) Old 09-26-2010, 11:07 AM
s ar tee 4's Avatar
Quoted: 4 Post(s)
how about some plug gapping info if possible, i think im getting some spark blow out right, now and it would be extremely helpful thanks.
s ar tee 4 is offline
post #5 of 22 (permalink) Old 09-27-2010, 02:19 PM Thread Starter
Quoted: 0 Post(s)
Good Idea sir. Ill get with Brandon again. Ill make sure that we have the gaps as the come in the box and what we recommend on them. Thanks for the input.
post #6 of 22 (permalink) Old 09-27-2010, 04:51 PM
s ar tee 4's Avatar
Quoted: 4 Post(s)
thanks alot man i appreciate it.
post #7 of 22 (permalink) Old 09-27-2010, 06:45 PM
turbotrix2004's Avatar
Quoted: 0 Post(s)
i guess i need me some NGK#2315
MODS Mopar Cai, DW 750 Injectors,DSP,Koyo Radiator,EDSB bfmic,70mm boomba tb,BC s3 cams springs & retainers, unorthadox Cam Gears,AIT crank pulley, P&P head,ported IM, gt3076r,DCR Complete oil kit,DCR wiseco 8.5.1 coated pistons, JE rods,3" V6 downpipe,E.D. Hard pipes,custom Cat-Back,
turbotrix2004 is offline
post #8 of 22 (permalink) Old 10-06-2010, 11:26 AM
Quoted: 0 Post(s)
i just picked up some NGK 4306 plugs this week. Will they work with granetelli or MSD spark plug wires? Modern performance's website says that they may not fit with the 4306 or other weird plugs.
biggwilliamz is offline
post #9 of 22 (permalink) Old 10-06-2010, 01:38 PM Thread Starter
Quoted: 0 Post(s)
Called up modern performance. They sell the combination all the time. They are a touch shorter but still work fine with the ngk plug.
post #10 of 22 (permalink) Old 08-11-2011, 07:21 AM
Quoted: 0 Post(s)
Not to bump an old thread, but would have been good to post gap adjustments (if any) in relation to spark plug.
This space is intended to be left blank until further notice.
psiturbo is offline
post #11 of 22 (permalink) Old 08-11-2011, 11:29 AM
all blacked out's Avatar
Quoted: 0 Post(s)
good thread to bring back up tho. about to replace mine so this is very good to know and also would like to know gap adjustments if need be?
all blacked out is offline
post #12 of 22 (permalink) Old 08-24-2011, 01:30 AM
greenneonsrt's Avatar
Quoted: 3 Post(s)
what would you consider higher than stock boost levels?
I'm currently running 17psi with s2 and stock plugs, would it benefit me to change heat ranges or stay the same as stock since it's not much more boost
greenneonsrt is offline
post #13 of 22 (permalink) Old 08-24-2011, 09:18 PM
SRT of the Month
underSRTarmor's Avatar
Quoted: 4 Post(s)
I'm running 23 psi and e85 I'm still on the 4306! I'm about to go with a 50 shot I'm going to lower the boost to 20 tho and retard time my 3 degrees! What's a good timing to be at with e85 and nitrous?
Maybe I should be using the 5107???
TUNED By MindMelt101
MyBuild Thread
10.99 @132.23 1.70 60ft 27 psi
Need Fuel setup ideas click here
Props go out to:
Mindmelt101, Tuner Geeks, Act, Wikyd Performance, Pwerks
underSRTarmor is offline
post #14 of 22 (permalink) Old 08-26-2011, 01:48 AM
ahmed24's Avatar
Quoted: 1 Post(s)
bump for appropriate Gap info!
ahmed24 is offline
post #15 of 22 (permalink) Old 09-16-2011, 10:47 PM
0liver'sSrt-4's Avatar
Quoted: 0 Post(s)
this!! want to know this aswell, im still using 4306 with nos and high boost.
5107s are 8.89 each, 4306s are 12 dollars all four.
0liver'sSrt-4 is offline
User Tag List
Linear Mode Linear Mode
