Old 03-08-2008, 11:50 AM   #1 (permalink)
SRTvidman's Avatar
Member Number: 1887
Default Some n3wb questions
I'm buying crackaddict's car (2004 srt-4 with 380 horse power)
The car has the 3147 kit and a bunch of other mods...
My question is:
How big of a shot of nos could I run safely? Would I need to upgrade my pistons and what not?
SRTvidman is offline   Reply With Quote
Old 03-08-2008, 11:56 AM   #2 (permalink)
Member Number: 11814
Trader Rating: (91)
You're going to actually want to check out the stickies. They have a fair amount of info........starting out with nitrous myself and I know from reading other threads the more knowledgeable ones in here are going to tell you to do that first.
I think the stickies have some pretty good info for beginners and would help with you're question and more.
Old 03-08-2008, 12:13 PM   #3 (permalink)
SRTvidman's Avatar
Member Number: 1887
I've read them over, but I still want some opinions on wether or not I should upgrade more to my engine to run NOS.
Here is the mod list...
- pWerks front and rear STB
- BC 30way Adjustable Coilovers
- Dtec FC/BC
- Dtec Tunerbox Wideband
- Bwoody Engine and tranny mounts
- Bwoody catch can
- dtec FC/BC w/ tuner wideband
- agp 3147 kit
- agp CAI
- agp BFMIC
- agp hot/cold pipes
- HKS SSQV
- agp IAT
- agp FRL
- Walbro 255lph Fuel Pump
- RC650cc Fuel Injectors
- needswings DP
- MadDog Short Shifter (72%)
- Stainless Shiftball (Pizzaboy)
- DCR Throttle Body
Old 03-08-2008, 05:38 PM   #4 (permalink)
Member Number: 37178
first off what is your goal? with that turbo it is almost pointless to spray it without a built motor. you could use a hobbs switch for spool. but with a big turbo stock block the most you would be able to spray is a 50 or so. and you would need race gas to do it any way. personally if i had your car and it was my dd i wouldnt spray it. just when i needed that extra power get a good race gas tune and turn that thing up to 29 or so.
v5 ecut, 3" tbe stock tips, mbc, stg 1, solid mm's, k&n, safc2, agp evm, ptp 75 psi mod, ptp wga, 23/16, wideband, cm wi custom 5 nozzle(100%meth), 100 shot, tbolts, fuel rewire.dual aeroforces, 3"02
ported parts: exh mani., intake mani, turbo, tb
nitrous posts
timing,fpr, octane safc
http://www.srtforums.com/forums/showthread.php?t=362819
big turbo,hobbs switch
http://www.srtforums.com/forums/showthread.php?t=371119
D_MONEY is offline   Reply With Quote
Old 03-08-2008, 05:55 PM   #5 (permalink)
04inred's Avatar
Member Number: 32838
Trader Rating: (12)
Ok so you read the stickies but they didnt answer your questions. YOu need a way to monitor knock also timing control, the FC/BC that you have is ok for the turbo but I have a friend that has blown up two motors partly because of hideng boost from the computer with a piggy back and getting to much timing. If you sell the DETC and get an Xcaliber frm SCT and get your car tuned for the turbo and the spray I dont see why you shouldnt be able to get away with a 75 shot. You will need to do a bottle neck fix and I would also recomend a fuel pump rewire so that your 255 is running at its best. With the piggy back you will have timing issues and most likely blow up the motor.
(\__/)
04inred is offline   Reply With Quote
Old 03-09-2008, 08:35 AM   #6 (permalink)
SRTvidman's Avatar
Member Number: 1887
I already plan on upgrading the clutch soon as it gets here. I also plan on getting forged pistons and some other motor upgrades. I don't need a huge shot, I would be happy with a 50 shot to be honest. Just something to have fun with at the track once in a while. I wouldn't use the nitrous anywhere else but the track.
Page generated in 0.24370 seconds with 11 queries
