Old 03-19-2009, 01:02 PM   #1 (permalink)
need4speed2345's Avatar
Member Number: 59269
Default seperate nitrous enrichment tank setup
So i recall that there is atleast one person who runs a seperate fuel system for nitrous. I would like to know what you used to piece it together. Did you have to buy each part sep? What are you running for your fuel source?
So far i put this together based on what i think would complete a system:
98.89 SUM-290122 Summit Racing Summit SUM-290122 - Summit® Nitrous Enrichment Fuel Cells - summitracing.com Fuel Cell
66.95 SUM-230620 Summit Racing Summit SUM-230620 - Summit® Stainless Steel Hose - summitracing.com Fuel Line
71.95 SUM-G3138 Summit Racing Summit SUM-G3138 - Summit® High-Flow Electric Fuel Pumps - summitracing.com Fuel Pump
139.95 Aeromotive 13109 Summit Racing Aeromotive 13109 - Aeromotive A1000-6 Injected Bypass Regulators - summitracing.com FPR
25.95 SUM-230101 Summit Racing Summit SUM-230101 - Summit® Full Flow Fuel Filters - summitracing.com Fuel Filter
7.95 SUM-220682 Summit Racing Summit SUM-220682 - Summit® Fuel Cell Bulkhead Adapter Fittings - summitracing.com 6an fitting for cell
3.95 SUM-220690 Summit Racing Summit SUM-220690 - Summit Racing® Hose Ends - summitracing.com hose ends
11.95 SUM-220687 Summit Racing Summit SUM-220687 - Summit Racing® Hose Ends - summitracing.com for fuel cell fittings
6.95 SUM-220166 Summit Racing Summit SUM-220166 - Summit® AN O-Ring to AN Adapter Fittings - summitracing.com FPR fittings
6.95 SUM-220166 Summit Racing Summit SUM-220166 - Summit® AN O-Ring to AN Adapter Fittings - summitracing.com fpr fittings
551.99 Total fuel system cost
Other than clamps and misc wire what am i missing?
03 SRT4-|Delta 44 Turbo|3 Inch CTI Turbo Back Exhaust|NOS Sniper Kit 50 shot|Coolingmist trunkmount Meth Kit|MBC 24PSI|MPx Front mount|750CC DW|AGP External Wastegate|378/402
93 Civic Hatch-STOCK D16 high boost build in progress
need4speed2345 is offline   Reply With Quote
Old 03-19-2009, 03:11 PM   #2 (permalink)
Member Number: 37178
looks good but way expensive way to do it. the first one i did before i was going to sell my car was almost the same except i used summit push lock line. but my new one is going to be with a 2qt tank from cooling mist and adapters from them also to use there line. with the same pump you have there and a diff. reg. should cost right about 300.
v5 ecut, 3" tbe stock tips, mbc, stg 1, solid mm's, k&n, safc2, agp evm, ptp 75 psi mod, ptp wga, 23/16, wideband, cm wi custom 5 nozzle(100%meth), 100 shot, tbolts, fuel rewire.dual aeroforces, 3"02
ported parts: exh mani., intake mani, turbo, tb
nitrous posts
timing,fpr, octane safc
http://www.srtforums.com/forums/showthread.php?t=362819
big turbo,hobbs switch
http://www.srtforums.com/forums/showthread.php?t=371119
D_MONEY is offline   Reply With Quote
Old 03-20-2009, 11:21 AM   #3 (permalink)
guessing you ran 100% meth as the fuel then?
Old 03-20-2009, 08:47 PM   #4 (permalink)
first setup i ran q16 this one eather meth or q16
Page generated in 0.16857 seconds with 13 queries
