Old 06-16-2009, 10:36 PM   #1 (permalink)
s ar tee 4's Avatar
Member Number: 54654
Default race gas/ nitrous
what are your ideas on spraying with out race gas.
im stg1, agp wg 15 psi,i want to at least make my way up to a 75 shot but im taking my time getting there.
and will i have timing issues with no way to really tune.
thanks for any help
s ar tee 4 is offline   Reply With Quote
Old 06-16-2009, 10:47 PM   #2 (permalink)
jaydawg1983's Avatar
Member Number: 62404
first....you will just have to add fuel to compensate.....how is this setup for ya
u can use a dsp or msd for the timing but im sure other people have some tricks
jaydawg1983 is offline   Reply With Quote
Old 06-16-2009, 10:55 PM   #3 (permalink)
s ar tee 4's Avatar
looks pretty amazing
i am running a wet kit
so just run a bigger fuel jet instead of race gas?
Old 06-16-2009, 11:01 PM   #4 (permalink)
what kind of shot do you plan on running.....what is your setup? i need to jet mine and put it on the dyno.....something smaller you shouldnt have a problem, you just have to match the jets so when you spray, you keep safe afs
Old 06-17-2009, 04:56 AM   #5 (permalink)
Rhunter's Avatar
Member Number: 36794
If you have basic bolt on's and only spiking 15 psi just jet it for a 50 shot. You will probably be on the fat side but until you get a wide band or do a dyno pull to determine your AFR's better safe than sorry.
I've sprayed on 93, but a gallon or two of race gas is good insurance. If you can't get that, or are cheap, just the the N.O.S octane booster. It works and cost about 10.00
remember using nitrous is not a begginer's class, it's an honor's class, because the results of a miscalculation or abuse can cause to a big time fail.
Old 06-17-2009, 03:41 PM   #6 (permalink)
s ar tee 4's Avatar
thanks. i do have a wide band but a 50 shot on straight 93 unleaded should be fine huh?
Old 06-17-2009, 03:43 PM   #7 (permalink)
s ar tee 4's Avatar
my set up is a nos single nozzle, still working on a window and a wot switch
Old 06-17-2009, 04:29 PM   #8 (permalink)
Rhunter's Avatar
You should be fine. Make sure you keep it a touch on the rich side. If possible hook up a scan gauge and do a pull to see what your timing is looking like.
Old 06-19-2009, 08:01 AM   #9 (permalink)
bribri's Avatar
Member Number: 33121
Trader Rating: (10)
i ran a 75 shot on the same setup as you with a few more bolt ons...NOS kit, 41N 21F and it runs perfectly...AF starts at 10.9 and rises to about 11.4, no race gas...i cant measure knock but i dont think it can be to bad...i was not pulling any timing
Rule of thumb is pull 2* of timing after 100shot, then 2* every 50hp shot more...honestly i think your safe...just make sure you turn the boost down when you spray cause it will up the boost for you 2-4psi...you dont wanna go over 17-18psi
works pretty damn good and its a nice power increase...i gained 95hp and 126ft lbs @ the wheels...!
bribri is online now   Reply With Quote
Old 06-19-2009, 01:25 PM   #10 (permalink)
04inred's Avatar
Member Number: 32838
You can try some E-85, a couple of gal will give you some protection and its cheap. I ran a 75 shot and got 110hp out of it with a fat hit of Tq but my timing was a mess.
(\__/)
04inred is offline   Reply With Quote
Old 06-19-2009, 07:33 PM   #11 (permalink)
s ar tee 4's Avatar
well i watch the afrs as much as i can, they are in the 10.s towards redline so im thinkin im good. im suprised how smooth it is when you hit the button, but theres a pretty decent kick.think im addicted!!
Old 06-19-2009, 10:44 PM   #12 (permalink)
b careful dood
Page generated in 0.17163 seconds with 13 queries
