Old 01-08-2007, 08:26 AM   #1 (permalink)
milkman102299's Avatar
Member Number: 25193
Trader Rating: (15)
Default questions on this kit
found this while I was looking the other day. Right now just for background I have my safc pulling 25% fuel at all rpm bands average. None less than 20, still with an 11.3 fuel ratio at 22psi boost falling to 17. I wanted to set up a dry shot for a 50 shot. Obvously scale down the AFC settings for a little more fuel and less timing when spraying. Anyway for the price what do you think, and has anyone heard of this company. I have had a shop in Texas that swears by them but other than that nothing else.
http://www.dynotunenitrous.com/store...?idproduct=117
12.72@110 1.92 60' capitol raceway 205/50/17 faulken ziex tires 11-18--6 stock turbo
je 8.5-1 pistons .020 over-eagle H beam rods
agp standard 50 trim @23psi pump 28psi race
Greddy Profec B.-MSD DIS 2-SAFC II
PTP charge pipe
PTP 750cc-exhaust depot cold side pipe w/hks ssq
3inch intake-msd coil-stock CPU
side exit
Boomba Fuel Rail/AGP return line
Walbro 255-Dynotune 75 shot.
DCR powershift 2-balance shafts removed
milkman102299 is offline   Reply With Quote
Old 01-08-2007, 11:14 AM   #2 (permalink)
04inred's Avatar
Member Number: 32838
Trader Rating: (12)
Dude dont use a dry shot on and SRT-4. We dont have a MAF sensor so the car will not adjust for the extra air. Get a wet kit form Dynotune or where ever.(my kit is from them but I got it used) And got from there. when my foot heals I'll be spraying a 75 shot in mine. there are some local people on eastcoastboost.com that have n2o experince beoned mine. I live in stafford and I'll help if I can. I'm sure Hayabusa will get in on this but from what Ive read DRY is bad.
(\__/)
04inred is offline   Reply With Quote
Old 01-08-2007, 11:21 AM   #3 (permalink)
Trader Rating: (15)
I know dry is not the best option as far as future modding, But I can adjust the fuel with my afc. Going with a small shot just wondering what people think as long as I dont get crazy.
Old 01-08-2007, 11:43 AM   #4 (permalink)
Hayabusa's Avatar
Member Number: 31537
All I can say is dont do it. Just spend a few dollars more a get a wet kit. You might could spray a 35 shot dry, but why waste your money. Get a wet kit. If you dont you will regret it as you will spend almost as much and not be able to use much nitrous at all. You will be very limited on how much you can use with a dry kit. It is so much easier tuning with a jet than by playing with the computer.
Hayabusa
Wanna race a cop? Click here: http://www.tnbeattheheat.com/
Hayabusa is offline   Reply With Quote
Old 01-08-2007, 11:48 AM   #5 (permalink)
Hayabusa's Avatar
Modern Performance has a wet kit for under $400. They are great, but just shop around, and dont skimp on the kit. You will regret it if you go dry even if you can run a 35 shot. For the extra money you can easily run at least a 75 shot, and if you dont think there is a big difference between a 35 and 75 or a 50 and 75 just ask around.
Hayabusa
Old 01-08-2007, 12:57 PM   #6 (permalink)
Trader Rating: (15)
I understand what you are saying, thing is i know quite a bit about cars and nothing about nitrous. I understand what it does, but can someone explain why (since I have more than enough fuel.) I cant tune the car with a dry nitrous setting and use my w/i for knock. Basically I plan on setting it up so if the meth aint working the nitrous wont fire.
Old 01-08-2007, 01:39 PM   #7 (permalink)
allblacksrt2431's Avatar
Member Number: 37820
run the dry and adjust the fuel. I would rather trust a safc to add fuel instead of a solinoid. If you have no tunning device wet is the only was to go. but if you can tune in and out fuel dry is just fine, and alot easier to hide.
allblacksrt2431 is offline   Reply With Quote
Old 01-08-2007, 02:51 PM   #8 (permalink)
wannasupra's Avatar
Member Number: 32741
use the meth injection as your fuel. as long as the meth is spraying, that's just like running a wet shot. but if you run out of meth, you're fucked.
"Scoff not at my vile remarks horny fiend"
Quote: Originally Posted by unnecessary View Post
Son Of A Bitch!@#!#@@#! You made me hit my Knee on the desk!
Old 01-08-2007, 07:38 PM   #9 (permalink)
Trader Rating: (15)
that why I got the safety features for meth. when it runs out and looses pressure the power is set to cut off. What I plan to do with the nos is tie them together so if the meth ever cuts off for any reason, low meth or blown fuse the nos would follow
Old 01-09-2007, 11:21 AM   #10 (permalink)
Hayabusa's Avatar
Well do what you want, but the extra fuel you have is not enough for a 75 shot of nitrous. Are you planning on constantly changing you tune for nitrous, and then for street? I can tell you that with the stock system and a 35 shot of nitrous I still had to use a pretty good size fuel jet to get my a/f ratios into the 11.5 range. No I didnt have to use the same size I would have if my car had been tuned to 11.5 before the nitrous, but I still had to use fuel. If you read the site you sent a link to it says for Mass air flow cars. There have been lots of people on this board run dry systems. It can be done, but they are either running wet systems now, or they arent on the board any more. I cant tell you why, they just arent. Anyone who tells you that you shouldnt use a wet system just has not tried running a big enough shot to make it worth there time. I mean even if you can some how run a 50 shot, for $125 extra you can run at least 25more hp and that comes to $5 per hp. Where else are you going to get that kind of hp to cost ratio. But go ahead and try it and report back on your results.
Hayabusa
Old 01-17-2007, 09:00 AM   #11 (permalink)
SRToc Member
Member Number: 34774
im starting to look around about a nitrous kit when i get my srt next week, but i drive a wrx now and ifu know nething about hondas i got beat by a d15b with vtec in a crx spraying a 45 shot. pulled me by 2 cars where if no nitrous= uber pownage for the honda
KnoxSRT-4 is offline   Reply With Quote
Old 01-17-2007, 09:00 AM   #12 (permalink)
SRToc Member
my wrx was stock at the time of the race so there ya go
Page generated in 0.25419 seconds with 11 queries
