Old 03-21-2009, 06:52 PM   #1 (permalink)
Rhunter's Avatar
Member Number: 36794
Default Nuts, DSM, Dmoney. I need your help!!
Ok long story short. I old Valve cover was pretty bad off. I purchased a powder coated one. It looks real sweet. The only prob is, The line (PCV line I think?) that runs from the top of the VC to the intake mani has nothing to connect to! on my old VC the fitting is threaded. On the new one, I have no idea how to get this valve to fit so I can run it to the IM. My car is a 03 and I'm guessing that they changed the design of this fitting after 03? Pictures below! Help a brotha out!!
Shows the old valve cover. The fitting on the valve cover is threaded.
powder coated valve cover.
See the difference in size? What do I need to do to make this work? The thing looks fantastic!!! The yellow really pops on a black car.
Help!!!
Old 03-21-2009, 07:03 PM   #2 (permalink)
CJsStocker's Avatar
Member Number: 58783
Trader Rating: (38)
04-05 valve cover pcv system is like that.
edit: why is this in the nitrous section?
CJsStocker is offline   Reply With Quote
Old 03-21-2009, 07:05 PM   #3 (permalink)
sp33d's Avatar
Member Number: 14683
Trader Rating: (58)
yup ^^
Powered by: DCR/AGP/SCT/BWs256/Nitro-Meth 514whp @ 27psi
sp33d is offline   Reply With Quote
Old 03-21-2009, 07:11 PM   #4 (permalink)
CJsStocker's Avatar
Trader Rating: (38)
also you can buy the 04-05 pcv valve from your local dealer or from one the vendors. It basically is a snap then turn (kind of) compared to threads.
Old 03-21-2009, 07:16 PM   #5 (permalink)
Rhunter's Avatar
Because I can get answers from guys I deal with on a regular basis.
Old 03-21-2009, 07:24 PM   #6 (permalink)
CJsStocker's Avatar
Trader Rating: (38)
ahhh.. I see..... then write up a direct port nitrous how to, for me then?
Old 03-21-2009, 07:40 PM   #7 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (122)
Rhunter, what does the baffling (under the VC) look like in comparing the 03 and the newer 04/05's? Curious to know what was changed between the two other then the screw in PCV valve versus the twist lock on the newer ones.
Old 03-21-2009, 07:42 PM   #8 (permalink)
Rhunter's Avatar
I can't remember. I'll run to the garage and snap a quick pic for ya
Old 03-21-2009, 07:46 PM   #9 (permalink)
turbojack's Avatar
Thanks no hurry on it, its not an important issue or anything, I just would like to know.
Threads for the PCV are like pipe threads?
Old 03-21-2009, 07:47 PM   #10 (permalink)
Rhunter's Avatar
Old 03-21-2009, 07:49 PM   #11 (permalink)
Rhunter's Avatar
The PCV fitting screws in, it has a big nut on top of it.
Old 03-21-2009, 07:50 PM   #12 (permalink)
turbojack's Avatar
Would you like to sell the valve cover, if so how much shipped to NJ.
Old 03-21-2009, 08:15 PM   #13 (permalink)
CJsStocker's Avatar
Trader Rating: (38)
so the change in 04-05 from 03, is it an improvement or something to do with the emission regulations?
Old 03-21-2009, 09:48 PM   #14 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
i wish i had the '03 valve cover so i could get rid of the stock PCV valve and just run the PtP one
Old 03-21-2009, 10:38 PM   #15 (permalink)
Rhunter's Avatar
Do you thing the 03 with the screw type of pcv is not as big as a factory boost leak as the 04/05?
Oh Modern performance has the pcv valves for the 04/05. the shipping cost more than the part.
Page generated in 0.18594 seconds with 13 queries
