Old 12-05-2008, 02:02 PM   #1 (permalink)
04srt-4's!nEvErHiDe!'s Avatar
Member Number: 62487
Trader Rating: (31)
Default nitrous set up help
okay since its been dead in here i am going to ask for some help, i got my 50 trim kit w/ my 75 shot DynoTune kit, now i am wondering, i am going to be running the N2MB 2 step launch control, i am going to be using the WOT switch for the nitrous also. what can i do to stop the nitrous from spraying at the line, window switch?
thanks for the help
discuss
04srt-4's!nEvErHiDe! is offline   Reply With Quote
Old 12-05-2008, 02:23 PM   #2 (permalink)
daniel427ss's Avatar
Member Number: 51325
subscribing cuz this is something ive thought about (for when i get n20), and also what happens when u wot shift, are u going to hook something up that cancels the shot when u hit the clutch? (thats something i had in mind but dont know how)
srt stock motor mounts 4 sale
bunch of 350z parts for sale, cp pistons .020over, eagle rods, headgaskets, heads, timingcovers, etc. etc.
daniel427ss is offline   Reply With Quote
Old 12-05-2008, 02:27 PM   #3 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
I use a FJO controller Take use of the 1st gear lockout feature.
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 12-05-2008, 02:29 PM   #4 (permalink)
Trader Rating: (31)
wont detonation occur when you WOS and the nitrous is still spraying, or will the window switch cancel that out??
Old 12-05-2008, 02:33 PM   #5 (permalink)
On the FJO controller, you can be wide open throttle & in your window of operation, but until the tach swings past a preset rpms window, it will not engage the nitrous with the 1st gear lockout feature.
The other way is with a addition relay wired into the system. It's either operated by a button for like a 2 step or one on it's own. It's a wiring diagram for a trans brake setup will work for you if you want to go cheap. Wired button, relay, then your good to go.
As long as you hold the button, it won't spray, the second you release the party begins.
Old 12-05-2008, 09:01 PM   #6 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
when we release the user interface for the wotbox you will be able to do that. next week i will draw up a diagram and install of how to use a relay in conjunction with the wotbox so that you wont spray on the 2 step
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 12-05-2008, 11:27 PM   #7 (permalink)
Trader Rating: (31)
^^ sounds good thanks guys good info
Old 12-06-2008, 03:24 PM   #8 (permalink)
kliped's Avatar
Member Number: 54197
get the dyno tune digital tps switch, thats what i run, i have my nitrous cut off at 6100 so that i can no lift shift, and as for two step, the digital tps also has a 1st gear lock out feature.
OR if that doesnt satisfy you, you can run a little switch, like a switch that is used for WOT nitrous and mount it right in front of your clutch pedal so that when your not pressing the clutch, the switch is engaged, run the ground side of the nitrous and fuel solenoids through it, so that every time you press the clutch, the solenoids lose their grounds and shut off.
kliped is offline   Reply With Quote
Old 12-07-2008, 11:05 PM   #9 (permalink)
Trader Rating: (31)
yeah i am def leaning towards the dynotune digital switch
Old 12-08-2008, 10:34 AM   #10 (permalink)
FUELED70's Avatar
Member Number: 44621
okay I'm interested, first time i used the wotbox w/2step on spray I melted the valve on my tb. haven't used spray since. of course the dragstrip is closed for teh winter, but would like this set up before next race season
FUELED70 is offline   Reply With Quote
Old 12-09-2008, 02:32 AM   #11 (permalink)
93stang434's Avatar
Member Number: 49690
I powershift the shit out of my car with the nitrous on so does a friend of mine no problems at all.I'm talking a 50hp and a 65hp shot and i didn't have a problem with 75hp shot either come to think of it.
E1 w/ported 3" anti-surge cover,LCR fully ported ext.gated exh mani,3" o2 housing,3"SEE,N2MB boost box,
S2 injectors,diablosport predator,coolingmist w/m
255 pump,rewire,bottleneck mod,returnline
MPx bfmic,55 t-body,180 t-stat,DCR oil restrictor
Best E.T 12.12 Best MPH 118.71 DR's,full weight no n2o
Tuned by Nemo@Rage-Tek & myself http://www.srtforums.com/forums/f146...charts-480643/
93stang434 is online now   Reply With Quote
Old 12-09-2008, 02:37 AM   #12 (permalink)
slwsrt's Avatar
Member Number: 33680
Trader Rating: (18)
well if u run an msd window switch and have it shut off at like 5800 u can wot shift at 6k and not have a problem
legend killa
R.I.P
In remembrance of Steven "NightShade" Lorenz
4/4/06....gone but never forgotten
dyno proven
556.12 hp
516.22tq
22psi and rich as hell
slwsrt is offline   Reply With Quote
Old 12-09-2008, 12:34 PM   #13 (permalink)
but i think is different because we use a device that cuts spark for several milliseconds, wot box, n then thats the part we fear.
get a wot box n wotshift while spraying to see if all is good.
Old 12-09-2008, 09:52 PM   #14 (permalink)
NJ DSM's Avatar
Member Number: 46989
Trader Rating: (34)
Any way you can get this up by sat dude? planning on installing mine, and am currently running the dynotune digital window/wot switch.
My thinking was: Since its set on the dynotune switch to spray btw 3000-5900, when the WOT box activates at redline, when clutch is engaged. Shouldnt i in theory not be spraying by the since its going to be at 6K, after the window switch is closed.
Just been wondering also, as i have a 1st gear lockout and just havent played with it since ive only been spraying from 2nd gear pulls. Wanna hit the track soon and would like to use the 2-step. If im using the 1st gear lockout on the dynotune wouldnt it not matter than im WOT in 1st.
Just thinking out loud...maybe you can help.
351/390 on Mustang DynoSTOCK TURBO
RUN YOUR CAR NOT YOUR MOUTH
NJ DSM is offline   Reply With Quote
Old 12-10-2008, 03:57 AM   #15 (permalink)
Trader Rating: (31)
yeah if you use the 1st gear lock out you should not have a problem WOT shifting from 1st to 2nd, just have the window switch cut out at 6 so you can WOT shift
Page generated in 0.19463 seconds with 13 queries
