Old 07-07-2008, 02:47 PM   #1 (permalink)
Member Number: 23004
Default Nitrous and IAT sensor
I have done a lot of research and the only question I have is if anyone is spraying before the IAT (I am assuming that is the sensor in the cold side pipe..). I am trying to figure out where I want to mount my nozzle.
Dumetre is online now   Reply With Quote
Old 07-07-2008, 02:49 PM   #2 (permalink)
ritfordprobe's Avatar
Member Number: 53609
Yup, I have both my meth and my nitrous nozzles about 1" before the IAT sensor.
'03 SRT4 - 11.930 @ 119.68 - first pass with the new slicks
--My Mod List--
ritfordprobe is online now   Reply With Quote
Old 07-07-2008, 02:54 PM   #3 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (17)
I would mount it, so that it doesn't spray the sensor. You need to mount it, so the the spray hit the 90 degree bend in the intake tubing. That's so it tumbles so you get equal in most cylinders. If you mount it 4-6 inches from the TB, it will overwhelm the 1# cylinder.
Stg3 toys, ported head & intake, NX 4nozzle, progresser, wide ban, egt, fuel pressure, injen, samco, Mpx3", Maxxfab02,Greddy CC, Boomba's, AIS intercooler, STS, billet SS, .020 8-1 JE's, Eagle 4340 H beam rods, UDP, you name it I've done it Mopar Clutch
Don't be messing with my FJO!!!!
2 180+ Lph pumps feeding the bitch!!!!
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 07-09-2008, 10:08 PM   #4 (permalink)
Member Number: 37178
well i have it before the sensor and when i spray i get 38 to 40deg. of timing. thats a ton. ill be moving mine soon to the tb spacer so i dont get so much timing. so if you run it infront of the sensor just be prepared to run alot of octane to prevent detonation from the crazy timing. i have done alot of testing with timing and wi and nitrous with this car and i personally think that after the sensor is the best.
v5 ecut, 3" tbe stock tips, mbc, stg 1, solid mm's, k&n, safc2, agp evm, ptp 75 psi mod, ptp wga, 23/16, wideband, cm wi custom 5 nozzle(100%meth), 100 shot, tbolts, fuel rewire.dual aeroforces, 3"02
ported parts: exh mani., intake mani, turbo, tb
nitrous posts
timing,fpr, octane safc
http://www.srtforums.com/forums/showthread.php?t=362819
big turbo,hobbs switch
http://www.srtforums.com/forums/showthread.php?t=371119
D_MONEY is offline   Reply With Quote
Page generated in 0.14302 seconds with 11 queries
