Old 06-18-2008, 08:16 PM   #1 (permalink)
SILVERFLASH's Avatar
Member Number: 14893
Trader Rating: (54)
Default N2o Advise
I am very new to nitrous. I would like a 100 shot. I have plenty of fuel, return line, 255lph pump, bottle neck fix, bomba fuel rail. I have rc 650 if needed. I have ed hard pipes,bfmic,cams,exhaust. What would be the best kit to get or piece it together?
Viper pulls up...lol its a neon
viper: ( revs motor a little)
Neon:
viper:
Green Light!!!!!!!
Ok I need a couple more Mod's
SILVERFLASH is offline   Reply With Quote
Old 06-18-2008, 09:18 PM   #2 (permalink)
Rhunter's Avatar
Member Number: 36794
If you want a complete kit and I mean everything. goto www.nitrousoutlet.com
They have their own kit and it looks high quality. If I did not already have a kit, this is the kit I would buy.
03 SRT-4
Old 06-19-2008, 05:33 PM   #3 (permalink)
Trader Rating: (54)
more input please!!!!
Old 06-19-2008, 06:59 PM   #4 (permalink)
Rhunter's Avatar
Read the stickies. Everything you need to know is in em. I promise.
Old 06-20-2008, 04:38 AM   #5 (permalink)
Hayabusa's Avatar
Member Number: 31537
Unless you are running a direct port kit stick with a 75 shot or so. You will get more than 100hp out of it, but a 100 shot is just a bit to much for a regular wet kit on a 4 cylinder. It has to do with nitrous/fuel distribution and not whether the engine can habdle it. Also you tune with the fuel jets so no need for bigger injectors. Gte a wide band if you dont have it and for even better tuning get an egt sensor.
Hayabusa
Wanna race a cop? Click here: http://www.tnbeattheheat.com/
Hayabusa is offline   Reply With Quote
Old 06-22-2008, 02:36 PM   #6 (permalink)
Member Number: 51755
when my car had a stock turbo,i would push a 100 shot easy.....u will need a aftermarket clucth for sure,u will not need to put the 650s in ,as long as u put a wet kit in to ur car
agp 50 trim,agp returnline,agp hard pipes,meth injection,cai,teail bov,agp motor@tranny mounts,3inch full exhust,no cat,wideband,thu boost,udp,bfmic,255 fuel pump,grounding kit,,msd wires-coil-tech ad,afc neo,stage 3 c/m clutch
corvette303 is offline   Reply With Quote
Old 06-22-2008, 02:56 PM   #7 (permalink)
Trader Rating: (54)
Thanks for the advise read all the stickies very helpful. What do recommend for the window switch digital or analog
Old 06-22-2008, 03:01 PM   #8 (permalink)
i would say digital, but i naver used one in my car... i had a foot trigger,so when i let off the gas the n2o would turn off
Old 06-22-2008, 10:50 PM   #9 (permalink)
T8NTKLR's Avatar
Member Number: 55697
you could use somthing like a fjo progressive controller. it has a window switch built into it and if your gunna run that big of a shot you can progress into it instead of just hittin all at once. you will need a tach driver to install it also. its about 70.00 new. the fjo is about 200.00
05 red srt-4
stg2 toys, AGP WGA, Mopar clutch, MPX3" W/o2 housing, AEM UEGO, Injen SRI, APEXi turbo timer, Maddog80%, Mopar bov, Greddy catch can, AGP solid mtm, PTP CV, MSD 2-step W/slicks for sum nasty 60'
nitrous FTMFW
T8NTKLR is offline   Reply With Quote
Old 06-22-2008, 11:29 PM   #10 (permalink)
daniel427ss's Avatar
Member Number: 51325
give me the 650s i do need them ill give u my stg2s
got stg2 inj. for a trade or i can sell em
daniel427ss is offline   Reply With Quote
Page generated in 0.23101 seconds with 11 queries
