Old 11-27-2008, 08:07 PM   #1 (permalink)
NJ DSM's Avatar
Member Number: 46989
Trader Rating: (34)
Default My "First Timer" setup
Anyways after about 3 months of looking for parts and the right stuff to pop up for sale, I have started my install. Just looking for some feedback, as like I said it is my first time using the bottle.
My nitrous essentials include:
NX EFI kit w/ 10lb bottle. 75 shot jet in JMB cold pipe.
Liquid filled NX gauge on bottle.
Dynotune Digital window/wot switch.
bottle heater
purge
Power mods include:
3" o2/DP
wga
walbro 255
no intake(open turbo)
hardpipes
meth
SAFC1-untuned
Stock Injectors
Basically my intentions are to only spray on Q18 race gas. I'll be going on the dyno in December to get two different pulls done. First I want to tune the SAFC for 93 and the meth, no nitrous. After those runs look good and I'm happy, I'll want to run the 75 shot like I said on the 118.
It looks like from what I've read that people run stock injectors on the 75 as long as race gas is used. Should I be running the meth when spraying or am I just wasting my time? What I'm thinking is less knock better, no? Point me in a direction I guess is what I'm asking from someone with some more experience than I.
If it looks like I'm running out of fuel on the dyno then I think I'll either pick up some 750's or a portfueler.
Heres a pic of the purge/power switch w/ led
the heater is wired directly to the battery, since i couldnt get it hot enough off just the defroster switch. I've got to find somewhere to mount it, as now its on the pass. side floor.
351/390 on Mustang DynoSTOCK TURBO
RUN YOUR CAR NOT YOUR MOUTH
NJ DSM is online now   Reply With Quote
Old 11-28-2008, 12:52 AM   #2 (permalink)
Member Number: 37178
you have a wet kit? if your leaning out its not because your injectors are too small. it would be your fuel pump. with a wet kit the extra fuel is from the fuel noid. not the injection system. yes run your meth. it helps, some people will tell you not to but it doesnt really matter. also your regular tune will be for meth so that would make it lean if you didnt run it with. and the fuel jet would have to make up for that.
v5 ecut, 3" tbe stock tips, mbc, stg 1, solid mm's, k&n, safc2, agp evm, ptp 75 psi mod, ptp wga, 23/16, wideband, cm wi custom 5 nozzle(100%meth), 100 shot, tbolts, fuel rewire.dual aeroforces, 3"02
ported parts: exh mani., intake mani, turbo, tb
nitrous posts
timing,fpr, octane safc
http://www.srtforums.com/forums/showthread.php?t=362819
big turbo,hobbs switch
http://www.srtforums.com/forums/showthread.php?t=371119
D_MONEY is offline   Reply With Quote
Old 11-28-2008, 01:14 AM   #3 (permalink)
dave gregory's Avatar
Member Number: 25521
"no intake(open turbo)" No air filter ? nothing ?
2004 SRT4 powered by Forward Motion & DCR.
dave gregory is offline   Reply With Quote
Old 11-28-2008, 04:18 PM   #4 (permalink)
NJ DSM's Avatar
Trader Rating: (34)
I'm not leaning out, i havent even sprayed yet, first time will be on the dyno. I said if i do end up leaning out i'll just get bigger injectors.
Also not going to run my pump/meth tune while on the bottle, that would be stupid. I'll have a 0'd out safc setting for the spray.
Well its not a DD and i have it open. as in chicken wire-ish stuff clamped over it.
Old 11-28-2008, 04:30 PM   #5 (permalink)
Member Number: 38189
well your first mistake is tuning a nitrous kit with the car's primary fuel system, whenever you tune a nitrous system, you tune it with the fuel jet. as far as the fuel system goes, i would just upgrade to a 255 pump and returnline on a boost reference, that should give you all the fuel you need. I would run meth as every little bit helps
rico's-srt is offline   Reply With Quote
Old 11-28-2008, 05:17 PM   #6 (permalink)
Rhunter's Avatar
Member Number: 36794
I'm one of the guys who feels that meth with nitrous is a waste of time and money. If you are gonna be running 118 race gas, how much more do you think the meth will help? You are only planning on a 75 so will your EGT's be sky high that you need the meth?
I'm stupid, so I rely on the K.I.S.S method. K.I.S.S = Keep It Simple Stupid.
Rhunter is online now   Reply With Quote
Old 11-28-2008, 06:16 PM   #7 (permalink)
NJ DSM's Avatar
Trader Rating: (34)
As per my first post, i said i would have a setting on the afc, user 1 for meth/93, and another 0'd out setting for second user to use with the 118 and nitrous. 255 is in and i have a return line capped off while i wait for -an fittings in the mail.
thanks rhunter, i guess ill do a pull with it on/off and see what the tuner says.
Keep the feedback coming guys everything is appreciated
Old 12-03-2008, 09:44 PM   #8 (permalink)
NJ DSM's Avatar
Trader Rating: (34)
Thumbs up
Anyways i went out last night with about 8 or 9 cars to do some pulls and test out my kit for real the first time finally with my last 1/8 tank of 118.
Meth on @ 8psi and 35 shot. Fastest car out with us was a 118mph trapping Evo 8, and i pulled pretty much within a 1/2 car of it from 40-120. Happy with how few mods my car has and knowing i still have the 75 to get in
Old 12-04-2008, 05:41 AM   #9 (permalink)
congrats dude
Old 12-05-2008, 12:34 PM   #10 (permalink)
04inred's Avatar
Member Number: 32838
The 35 shot is a tease put the 75 in and role out.
(\__/)
04inred is offline   Reply With Quote
Old 12-05-2008, 05:58 PM   #11 (permalink)
NJ DSM's Avatar
Trader Rating: (34)
I KNOW DUDE! im gonna put it in sunday i think, since i still have 5 gals 118 left i can go make some pulls again and see how it runs cant even imagine, i was spinnin the DR's in 3rd as it is now lol
Im gonna post up the vids from tuesday night when i was shootin 35 in the vid section
Old 12-05-2008, 08:51 PM   #12 (permalink)
Rhunter's Avatar
good stuff man. Once you get that 75 shot, run that evo again.
I think it will be for him
Old 12-05-2008, 11:08 PM   #13 (permalink)
NJ DSM's Avatar
Trader Rating: (34)
Ya i know man, he knew my car back before i went back to stock and he was full boltons and he was amazed at the pull on the 35...comin back and rockin out with my cock out
Old 12-06-2008, 10:38 AM   #14 (permalink)
04inred's Avatar
With mine pulling timing and freaking out I made whats n my sig on a ritch 75 shot and pump gas.
Page generated in 0.22039 seconds with 13 queries
