Old 05-11-2008, 12:07 PM   #31 (permalink)
darooke's Avatar
Member Number: 26595
Trader Rating: (27)
nitrous is -127 degrees when exiting the bottle.
Now go get your shine box!
2005 Black ACR
Powered by Tune Time performance and N2MB
darooke is online now   Reply With Quote
Old 05-11-2008, 08:25 PM   #32 (permalink)
Member Number: 11814
Trader Rating: (89)
I need to look into finding out the details of how the line sizes, jets and bottle pressure effect things.
Off the top of my head I would think that the temp would be significantly less after entering into the intake tract.
I think I'm going to call the Holley/NOS support line on this to see what they say about the temp after the nozzle.
Old 05-12-2008, 08:08 AM   #33 (permalink)
darooke's Avatar
Trader Rating: (27)
cool, keep us updated.
Old 05-13-2008, 05:04 PM   #34 (permalink)
Trader Rating: (89)
Can't get a 100% factual answer how cold so far. Spoke to a Nitrous guru at Nitrous Outlet and he says he got several customers running nitrous with 100% methanol and its no big deal.
More or less he said even with a 50/50 water methanol mix the speed/velocity of the air charge in the intake tract does not allow time for freezing of either. When I asked him about the freezing issue he mentioned it as a misnomer something along the same line as puddling in an intake manifold plenum = if the nitrous and fuel system is setup and used correctly its not an issue.
He also mentioned that the methanol when used with nitrous is for addtional fuel/octane and does nothing for intake air charge cooling when used with nitrous = doing more cooling when its injected then methanol could ever do.
Even though I have not spoken to everyone I can think to trust with the question, my thinking at this point is that unless the methanol nozzle/jet is leaking OR if the methanol delivery system is weak in design and function its a go for using methanol with nitrous. Note: I have Spoken to Richard L at Aquamist, he mentioned that nitrous with methanol injection has been done for quite some time and its not new or really tricky, but like anything whether some one sees good or bad comes down to the components, the install, and how its used.
Right now I do not have scientific evidence via testing to back up the potential freezing issues but so far I have not had many people tell me it should not be done. I'll have to talk to a couple of more long time nitrous guru's to get more feedback.
Old 05-14-2008, 02:40 PM   #35 (permalink)
Rhunter's Avatar
Member Number: 36794
Good post Turbo Jack. I'm still on the fence about the added expense, but if you already have the meth kit, might as well use it to up octane.
My issue with using both had nothing to do with freezing, pleny on this forum have ran both and not come across problems.
My issue is more a performance vs tuning/expense issue. In other words, is it worth going through the trouble to install, tune and run both.
03 SRT-4
Old 05-14-2008, 04:38 PM   #36 (permalink)
Trader Rating: (89)
Rhunter, you are correct and the guy at Nitrous Outlet mentioned the same thing. From starting at scratch standpoint is not worth buying both.
With an existing methanol injection system on hand things can be tweaked to use the methanol and the nitrous at the same time and benefit from it. I'm way too big into Water/Methanol injection not to use it, nitrous injection is new territory for me.
Page generated in 0.23363 seconds with 11 queries
