Old 06-04-2009, 10:33 PM   #1 (permalink)
JiM P 2001's Avatar
Member Number: 40408
Default Jetting & Timing
I'm going to yank some timing out of my car before I spray a massive shot on it. Anyone have the general rule of thumb for timing to shot ratio?
I was planning on pulling 2* for every 50. I'm starting at a 100 shot and working my way up until I reach my desired E/T and trap, or the thing pukes it's rods all over the track. Sound about right?
Black 2004 Dodge Neon SRT-4
Hotchkis Springs & Swaybars
S2 w/ Toys, AEM CAI, MPx FMIC, AGP WGA, Full Stock TBE, Gutted Cat, 22psi, VP C12 Fuel
On Streets, Off Spray: 12.80@114 2.2 60'
On Slicks, Off Spray: 12.24@112 1.74 60'
JiM P 2001 is offline   Reply With Quote
Old 06-05-2009, 08:22 AM   #2 (permalink)
Rhunter's Avatar
Member Number: 36794
Is there knock? I've never sprayed 100, just wondering how much KR you are seeing.
Old 06-05-2009, 02:59 PM   #3 (permalink)
neonmarine's Avatar
Member Number: 21010
Trader Rating: (32)
What do you have to monitor Knock? and what are you using adjust timing?
neonmarine is offline   Reply With Quote
Old 06-05-2009, 04:05 PM   #4 (permalink)
JiM P 2001's Avatar
I haven't sprayed it yet. I'm using a scan gauge to keep an eye on knock and will be using SCT to re-flash. I'll be using NGK 2 step colder plugs and VP C16 fuel when I'm spraying.
Stock turbo, stock engine, 22psi spike, using n2mb n2o control off wot box
Old 06-05-2009, 04:19 PM   #5 (permalink)
rrmike1's Avatar
Member Number: 55729
You really don't need the C16. I've been spraying a 50 shot on my mods with no knock whatsoever. Don't take out any timing unless you're getting knock...
Mopar S2 no toys, FBM pnp'd turbo/mani., Rage 55mm T/B, AGP WGA, AGP CAI, MPx 3" O2, Maxxfab 3" DP, Mopar Exhaust, AEM UEGO, SprayItRacing BOV, Crane 8.5mm wires, Champion RE10pmc5's, Stant 180 thermo, Prothane race MM inserts, Autometer 30/30, Tein H's, Proparts dual-gauge pillar, Fuel pump re-wire, NOS Sniper kit
rrmike1 is offline   Reply With Quote
Old 06-05-2009, 07:02 PM   #6 (permalink)
neonmarine's Avatar
Trader Rating: (32)
I've seen, in person, couple of guys spray a single fogger 75 shot with no problems. Many claim the same over the net and on the forums. Drop your spike down to 19ish and have fun. C16 is pointless.
Old 06-05-2009, 07:05 PM   #7 (permalink)
neonmarine's Avatar
Trader Rating: (32)
BTW, that gutted cat is more of a restriction now then when it was stock. I'd do something about that. Just my 2 cents.
Old 06-05-2009, 07:13 PM   #8 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
ive sprayed 100+ on a fogger lol
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 06-06-2009, 01:49 PM   #9 (permalink)
JiM P 2001's Avatar
Next mod is a maxxfab 3" SEE and O2 housing... I've been cheaping out on exhaust for 2 years now...
I'm gonna run C16 in the car because I'm starting out on a 100 shot. I'm going to increase the shot in the staging lanes at the track until I reach my goal for my setup. It will probably end up being a ~150-180 shot when it's all said and done.
Enjoy staring at my broken dipstick (handle snapped off when I went to pull it out yesterday, WTF!) and yes, I know the hose from the valve cover to intake is ripped.
Old 06-08-2009, 05:17 AM   #10 (permalink)
neonmarine's Avatar
Trader Rating: (32)
Looks good....Is there anyway you can do some AFR testing on a smaller shot before the track date? Once you confirm you're good, uping the jetting will be a snap. But if your AFR's are off on the small stuff, we all know what will happen on larger shots.
I found that the air/fuels stayed true, once the baseline was tuned. All you have to do after that is reach for the nexted size up!
Also, using a dyno isn't just for number hunting. The first time I sprayed on the rollers, my #3 cylinder went lean due to a leak on the fogger to fuel line connection. Lucky for me, I was standing right there, watching and immediatly shut the dyno operater down to fix the leak.
Old 06-08-2009, 07:22 AM   #11 (permalink)
Rhunter's Avatar
Jim,
That is a friggin sweet set up! !
The time to beat is 11.3.
The fastest time this year on stock turbo & nitrous is 11.5
Have fun boys
Old 06-09-2009, 05:07 PM   #12 (permalink)
JiM P 2001's Avatar
I'm gonna end up smoothing out the AFR on the S2 computer and spraying on top of it. Right now I'm running a 255 with a 10awg rewire, bottle neck fix, aeromotive FPR, -6 Feed, -4 return, 58psi static, no boost reference. If I do the boost reference, that's gonna bring the fuel pressure up to 80psi at peak boost, isn't that a bit much? I just want to get this right the first time. Any tips on fueling, etc would help a lot.
Quote: Originally Posted by Rhunter View Post
Jim,
Have fun boys
Thanks man! I'm trying to shatter the record and get a 10 second pass on a stock engine/turbo. Nothing touched from the throttle body to the turbo, no port work, etc.
Old 06-09-2009, 08:18 PM   #13 (permalink)
neonmarine's Avatar
Trader Rating: (32)
I ran mine with a boost reference to a Aeromotive FPR 1:1. 22psi spike also. My advantage was a DTEC map just for spray. I had the "hit" leaned up, (too rich) and smoothed out the rest of the way. But that was my method. It worked. Hope this helps.
Old 06-09-2009, 08:22 PM   #14 (permalink)
neonmarine's Avatar
Trader Rating: (32)
BTW, I had a 255lph BN fix, -8 feed, -6 return with a Boomba rail. You have a better system than me.
Old 06-09-2009, 10:39 PM   #15 (permalink)
JiM P 2001's Avatar
I guess this is my concern, and correct me if I am wrong, because this is my first car with boost, as well as with nitrous.
If my static stock fuel pressure is 58psi, and I run 22psi of boost, the 22psi of boost will be pushing back the fuel with 22psi of force.
Therefore, 58 - 22 = 36psi
So, without running a boost ref off my aeromotive FPR, I should jet the nitrous as if the car was only making 36psi of fuel?
I assume that the aeromotive FPR is a 1:1 ratio increase? +1psi of boost = +1psi of fuel? Isn't an 80psi spike a lot of pressure to send into the injectors? I was told by the guy tuning my car that it's dangerous to run that much FP because the injectors can lock up...
I pretty much have no clue of what I'm doing. I need to go back to RWD carbbed small blocks..
Page generated in 0.20309 seconds with 13 queries
