Quote: Originally Posted by
bribri
*EDIT* South Florida serves 93 octane
Well I have the boost set to 17psi with the downpipe open. Honestly I don't think I will be spraying the car that often. Im just gonna have it if I need it and for the track (which i go to twice a year if that)
Any ideas on the jet sizes? Im looking for info on it. Im gonna have a wideband to tune the car with. Its not mine so im gonna have to give it back after im done getting the jets right. What kind of A/F ratio should I be aiming for?
Thanks
When I plan on spraying I up the octane. 93 is great compared to the 91 piss water they have out in Cali but I personally won't spray on 93. I recommend some race gas or at the very least N.O.S brand octane booster (about 7.00 a bottle and works!!!) or Torco fuel excelorater (about 17.00 a can). Better safe than sorry.
As far as A/F ratio, I have not gotten to the point of my nitrous tune. I've only sprayed the car like 4 (race gas or torco each time)times, and since I've been back to the states I have not had time to get into tuning the car.
I'm gonna get a A/F reading before spraying, then spray the car and get another reading. From the 2nd reading I will adjust the fuel jet. If it car is rich (most seem to be when spraying) I'll go down one fuel pill size. If it looks lean, then I'll try go up one fuel pill size size.
Don't get to rapped around the axle with HP jetting. You BP will also play a big part in "how much" you are spraying. I would start with jetting for a 75 shot and adjust your fuel pill from that jetting.
I'm sure the real pro's will chime in and add anything I've missed.
